Doesnt Go for Step-2 at check out
14 years 5 months ago #51378
by cimran
Doesnt Go for Step-2 at check out was created by cimran
www.gmsaboriginalart.com/index.php/for-s...checkout/step/step-1
It doesnt go for step-2 on checkout
Plz check with
Username: cimran
Password: yasir456
thanks
Plz check with
Username: cimran
Password: yasir456
thanks
- Thank you received: 1778
14 years 5 months ago #51389
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Doesnt Go for Step-2 at check out
You'll just have to :
- Go to "Hikashop -> System -> Configuration -> Checkout"
- Set the "Advanced checkout workflow edition" to YES
- add more step like for example ==> 1st step : Login 2nd step : address shipping 3rd step : ...
Hope this will help you a little.
14 years 5 months ago #51410
by cimran
Replied by cimran on topic Re: Doesnt Go for Step-2 at check out
It worked
thanks alot
It worked
thanks alot
