No debug info on ups shippinng
9 years 3 months ago #275749 by jbendsen
-- Joomla version -- : 3.7.4
-- PHP version -- : 7.0.22
I don't get any UPS quotes in checkout, so I set the UPS shipping method to debug, but I don't get any debug info, please help.
Jesper
9 years 3 months ago #275756 by Mohamed Thelji
Hello Jesper,
You probably don't have any debug information through the HTML code of your checkout page because of the checkout cache.
Can you show us some screenshots of :
- How you configured your UPS shipping method
- The product that you have added in your cart when you have tested it
Thank you.
9 years 3 months ago #275789 by jbendsen
See the two attachments..... the FedEx is working as you can see, but not the ups, not even the debug..
Please help get the ups debug to work
Jesper
9 years 3 months ago #275808 by nicolas
What you can first do is deactivate all the other shipping methods to leave only UPS activated. Then, on the checkout, when no shipping method will be displayed, you should see the error message from the UPS plugin explaining why it can't find any rates.
9 years 3 months ago #275824 by jbendsen
hi Nicolas
It just says 'no shipping method found' still no debug info?
see attach
Jesper
9 years 3 months ago #275883 by Mohamed Thelji
Hello Jesper,
As I said about the debug mode :
A solution can be for example to change some digit of the phone number of your customer shipping address then it will reprocess the UPS platform call and you'll have the debug through the HTML code of your checkout page.
Also, I'll need some screenshots of how you configured the product that you have added on your cart so that I can reproduce it on my end.
Thank you.
9 years 3 months ago #275925 by jbendsen
I changed both the address and the phone number, but still no ups shipping rates....
See attach..
HS product attached
Also I use the same US credentials on my virtuemart install, and here I get a rate back from UPS,..
See attach...
Please fix so I can get rid of virtuemart...
Jesper
9 years 2 months ago #276053 by Mohamed Thelji
Hi Jesper,
I just said that by changing one parameter of your shipping address, your cache will refresh and another UPS request will be triggered through your checkout workflow. It won't fix your issue, but you'll have on your page html code (can generally be checked by pressing "F12" through your browser) the request that was sent to the UPS platform and also the reply, which will help us to understand your issue.
Can you send us a temporary back-end access to your website through our contact form so that we can directly reproduce and check it on your website ?
Don't forget to add a link to that thread on your message so that we can quickly identify what we'll have to check on your website.
Thank you.
9 years 2 months ago - 9 years 2 months ago #276153 by Mohamed Thelji
Hi Jesper,
I tried to reproduce it on your end, but also on my end using your credentials, so you'll find attached the request that was made to the UPS platform and also their reply.
You can show them these request/response to have more information about your issue.
Last edit: 9 years 2 months ago by Mohamed Thelji.
9 years 2 months ago #276179 by jbendsen
Could you tell me how I can myself get the debug info?
And remember the same ups credentials works on my live virtuemart site....
9 years 2 months ago #276180 by jbendsen
What does it mean when your UPS plugin sends the measurement in LBS/IN as seen in the code:
<Dimensions>
<UnitOfMeasurement>
<Code>IN</Code>
</UnitOfMeasurement>
<Length>3.94</Length>
<Width>3.94</Width>
<Height>3.94</Height>
</Dimensions>
<PackageWeight>
<UnitOfMeasurement>
<Code>LBS</Code>
<Weight>0.551155585</Weight>
</PackageWeight>
and the reply from UPS is:
"This measurement system is not valid for the selected country"
and that the selected configuration for 'Units' in the 'HikaShop UPS shipping plugin' is set to KG/CM?
It makes me believe that the 'HikaShop UPS shipping plugin' has a bug, because the 'Units' is set to 'KG/CM' but it sends the 'Unit' as LB/IN to the UPS server. If you agree please correct the 'HikaShop UPS shipping plugin'.
9 years 2 months ago - 9 years 2 months ago #276211 by Mohamed Thelji
You're right, we just have added a fix through the last UPS shipping plugin version. I also have imported that last UPS shipping plugin version through your website, and it seems to be working fine now.
Thank you for your feedback !
9 years 2 months ago #276472 by jbendsen
Thanks, how do I get that version to my production site?
9 years 2 months ago #276477 by jbendsen
Also please tell me where to find the debug logs....
9 years 2 months ago #276480 by jbendsen
The currency conversion for the UPS shipping does not work. If something cost DKK 300 in UPS shipping and I change the currency to US$ then the same UPS shipping now cost US$ 300. Please fix.... :-)
9 years 2 months ago - 9 years 2 months ago #276476 by Mohamed Thelji
It should be working fine know. Else you can also have that last version by downloading the last Hikashop version through our website, install it and test it again.
You'll find it through your checkout HTML code by enabling the "debug" option of your UPS shipping method.
Sure, but I just tested it on my end and it seems to be working fine, the UPS shipping platform is returning rates in DKK and then hikashop is correctly converting it to €.
Can you tell me exactly how you are changing your shop currency ?
9 years 2 months ago #276581 by jbendsen
I just went to the site and, put a product in the cart, went to checkout and there was no debug info and no shipping method, so either does not work, can you please look into it?
see attach.
Jesper
9 years 2 months ago #276585 by jbendsen
Then I did a refresh and the screen showed the shipping methods, I would very much like the shipping method to be shown without my customers having to do the refresh... see attach
9 years 2 months ago #276586 by jbendsen
Then I changed from currency DKK to US$ and there was no conversion, please fix, see attach...
9 years 2 months ago - 9 years 2 months ago #276606 by Mohamed Thelji
You probably had to refresh because you still had in cache the old shipping methods for your current cart, so your customers won't face that issue.
I again, just installed the last UPS shipping version through your website and the shipping amount was being updated when the currency was changed.
Can you download the last Hikashop version through our website, install it and test it again ?
Thank you for your feedback.
