Checkout workflow: 2 click on next
15 years 7 months ago #13691 by Galassi
This is my Checkout workflow: cart_shipping_payment,login_address,confirm_status_terms,end
When I'm at step one and click on Next button will charge the same step cart_shipping_payment. Click again on the next button step login_address is loaded.
15 years 7 months ago #13709 by nicolas
We cannot reproduce that problem on our end. Could you do a screenshot of all the options of the tab checkout of your configuration ?
If you try to use your checkout workflow on our demo website, it should work for you too without having to click twice, do you confirm ?
15 years 7 months ago #13711 by Galassi
I tried to reproduce the configuration on the demo site and the problem is the same.
15 years 7 months ago #13715 by nicolas
That's because you have the auto select option off and that you're displaying the cart on the same view as the payment methods. So the system displays again the same view in order to confirm the cart changes (later on, the total price might change based on the payment method selection, like it happens now with the shipping).
If you activate the auto selection option or change your checkout workflow, that should solve the problem.
