importing products
15 years 6 months ago #14998 by sandy
importing products was created by sandy
I have a csv file with 168 product lines.
Some of them are already imported earlier, but now the list is bigger.
So when I import the file, I get following message:
Notice: Undefined property: stdClass::$product_id in /var/www/html/administrator/components/com_hikashop/helpers/import.php on line 791
Notice: Undefined property: stdClass::$product_id in /var/www/html/administrator/components/com_hikashop/helpers/import.php on line 793
Notice: Undefined property: stdClass::$product_id in /var/www/html/administrator/components/com_hikashop/helpers/import.php on line 1019
Notice: Undefined property: stdClass::$product_id in /var/www/html/administrator/components/com_hikashop/helpers/import.php on line 1022
Notice: Undefined property: stdClass::$product_id in /var/www/html/administrator/components/com_hikashop/helpers/import.php on line 843
Notice: Undefined property: stdClass::$product_id in /var/www/html/administrator/components/com_hikashop/helpers/import.php on line 845
When I check all my products under their categories, and count them, then I only have 94 products, instead of 168.
do you know what is going wrong and why some of the products are not imported?
Thx,
Sandy
15 years 6 months ago #15011 by nicolas
Replied by nicolas on topic Re: importing products
Since that's the first time someone reports such issue, we need more information from you before we can help. What version of HikaShop are you using ?
Could you copy the header of your csv file and few lines of products which didn't import ?
15 years 6 months ago #15033 by sandy
Replied by sandy on topic Re: importing products
this is the header:
"product_name","product_description","product_quantity","product_sale_Start","price_value","categories","images","product_published"
and these are some lines that are not imported:
"Ball closure ring Gauge: 1,6 intern. diam.:10","Ball closure ring <br/>intern. diam.:10 <br/>colour:blk <br/>colour ball:black <br/>material:steel",1,25/04/11,15,"ball closure ring 1 ball","ballclosureringbb.jpg","1"
"Ball closure ring Gauge: 1,6 intern. diam.:12","Ball closure ring <br/>intern. diam.:12 <br/>colour:blk <br/>colour ball:black <br/>material:steel",1,25/04/11,15,"ball closure ring 1 ball","ballclosureringbb.jpg","1"
"Ball closure ring Gauge: 1,6 intern. diam.:8","Ball closure ring <br/>intern. diam.:8 <br/>colour:blk <br/>colour ball:black <br/>material:steel",1,25/04/11,15,"ball closure ring 1 ball","ballclosureringbb.jpg","1"
no product from the categorie 'ball closure ring 1 ball' is imported, i'm not sure if it has somethin to do with the category or not.
I have hikashop 1.4.9
Thx,
15 years 6 months ago #15036 by nicolas
The problem must come from somewhere else in your CSV file because these lines are fine.
If you copy/paste the header and these lines in the "import from textarea" screen, it should work properly. Do you confirm ?
I'm afraid that we would need the full CSV file in order to see where is the problem...
15 years 6 months ago #15042 by sandy
I confirm,
this is the whole csv file.
15 years 6 months ago #15048 by nicolas
I can see that a lot of products have the same name in your CSV file.
That's probably why you're missing products.
If you don't specify the product_code in your CSV, the system will use the product_name as product_code.
And the product_code must be unique. If the product_code already exists in the database, HikaShop will update its information.*
15 years 6 months ago #15070 by sandy
Ok, i'll make up unique names.
Thx!
15 years 6 months ago #15109 by sandy
solved! thx
