Manual shipping problem
15 years 2 months ago #24973
by doydot
Manual shipping problem was created by doydot
I added 30 or so new shipping options via the manual shipping plugin and decided to put them in the correct order. After changing them to the correct order I clicked the order icon. Instead of putting my products in order, it has duplicated my 30 I had originally to 1400. There does not seem to be an option to check what I don't need and delete it all but have to delete them 1 by 1.
Is there a database for only this section which will be easier to delete/modify?
I have Windows 7, IE 9, Joomla 1.6 and the latest Hikashop - (You have the latest stable version : 1.5.3)
Website:
www.rchelicoptersandhobbies.com.au/
No payment methods are currently published until this issue is sorted out. (Sept 2011)
Any help would be greatly appreciated
Website:
15 years 2 months ago #24974
Replied by nicolas on topic Re: Manual shipping problem
You should empty the table jos_hikashop_shipping in your database via phpmyadmin. That will remove all the shipping methods.
This is a known bug which is still in 1.5.3 and which we found out about 2 weeks ago. It has been corrected on our end and the fix will be included in next release which will be out next week or in two weeks.
In the mean time, you should add your manual shipping methods in the good order or modify the order directly in the table jos_hikashop_shipping.
15 years 2 months ago #24975
by doydot
Replied by doydot on topic Re: Manual shipping problem
Thanks Nicolas, worked as suggested. Thanks for quick response. I will await new update
- Thank you received: 1
15 years 2 months ago #25398
by Spacehangout
Replied by Spacehangout on topic Re: Manual shipping problem
Empty the table jos_hikashop_shipping in the database via phpmyadmin.I think this will work hopefully for me.
15 years 1 month ago #25699
by robert.bulman
Replied by robert.bulman on topic Re: Manual shipping problem
I hit this problem myself, today. Ironically, this ‘quirk’ was actually helpful, because I was creating about eigthy-five new Manual Shipping Methods and I was able to use each 'copy’ for my next new method.
