No Payment Method Found! HELP!!
14 years 11 months ago #30811 by michaelbuttitta
I have both PayPal and PayPal Pro enabled in my cart, and I am getting this error "No Payment Method Found" when a user goes to checkout and they CLEARLY have PayPal indicated for payment.
This is becomito leave. PLEASE! I need help getting these issues fixed!
Michael Buttitta
Hot Picks USA
14 years 11 months ago #30824 by nicolas
That's because in your payment methods options, you restricted them to only one shipping method.
I've unselected that restriction as you already gave us a back end access and the problem is solved.
14 years 11 months ago #30863 by pekuiper
I just up dated to the Business and now I am getting the "No payment methods found" error. Can you help me
14 years 11 months ago #30864 by nicolas
That always comes from one of the points of that FAQ:
www.hikashop.com/en/support/documentatio...ins-listing.html#faq
Please check them out. If you don't find the answer there, please post a screenshot of your payment method options.
14 years 11 months ago #30865 by pekuiper
I checked them all. If I activate my Authorize.net payment plugin is shows up but not my paypal. Problem is my Authorize.new is not completed yet.
Everything was working till I up-grated to HikaShop business this morning.
14 years 11 months ago #30866 by pekuiper
Must not have taken my photo the first time, sorry
14 years 11 months ago #30867 by nicolas
You should deselect the shipping method restriction you set there and try again.
14 years 11 months ago #30869 by pekuiper
No luck.
14 years 11 months ago #30870 by nicolas
Now I see that you selected both a shipping method AND a currency restriction.
To deselect a selection in a multi select, you should maintained pressed the ctrl key on your keyboard and then click on the selected items. Then, save the payment method and it should work.
14 years 11 months ago #30871 by pekuiper
WOW, brain fart - yes it worked. Don't know why I clicked it in the first place. Thanks for your awesome help.
14 years 10 months ago #33303 by Jabatec
a solution
HikaShop -> configuration
disable auo submit.....
by
Javier
Javier Ballester
14 years 1 week ago - 14 years 1 week ago #74834 by g5_macdaddy
I have read threw the forms and tried everything that could stop the "Authorize.net payment plugin" from working.
I had upgraded the HikaShop so that I allow users not to have to register and just buy products...
Anyways now my Authorize.net payment plugin wont work.
Please see screen shot. And may I just give you access to the site Nicolas?
Dan
Last edit: 14 years 1 week ago by g5_macdaddy. Reason: Spelling
14 years 1 week ago #74847 by g5_macdaddy
turns out "Authorize.net payment plugin" is for USA currency only and if your main currency is set to anything other the us dollar it will not work.
So two places to make sure you have USD.
Configuration / System / Main "Main currency" $USD
Configuration / System / payment methods / HikaShop Authorize.net payment plugin / "price" USD
Now this is an issue for Canadian shopping carts.
If you have a work around please let me know.
14 years 1 week ago #74861 by nicolas
The Authorize.net payment gateway is only for USA based merchants. There is no work around for that. You'll have to use another payment gateway if you're in Canada.
14 years 1 week ago #74868 by g5_macdaddy
Just to let you know I am using a Canadian and US merchant "federatedgateway.com"
They use authorize.net plugin to enable their cart. By replacing the fields with Federated gateway merchant info the cart works. Virtuemart also has the same deal with authorize.net plugin.
I am stuck with this merchant because the client wants to use them.
Sigh
14 years 1 week ago #74877 by nicolas
In that case remove the code
if(!empty($currency) && @$currency[$currency_id]->currency_code != 'USD'){ return true; }
in plugins/hikashoppayment/authorize/authorize.php and the plugin should work for CAD.
Time to create page: 0.113 seconds
