Export products-info, manufactures, variant
- Micke_skane
14 years 5 months ago #51661
by Micke_skane
Export products-info, manufactures, variant was created by Micke_skane
Hey,
Is it possible to export info about manufactures and variant-name and variant-images when you choose to export the products in
Hikashop?
/Micke
Hikashop?
/Micke
14 years 5 months ago #51729
Replied by nicolas on topic Re: Export products-info, manufactures, variant
Yes, when you export products via the export button of the products listing, you get the variants and the manufacturer and the images names in the CSV.
- Micke_skane
14 years 5 months ago #51738
by Micke_skane
Replied by Micke_skane on topic Re: Export products-info, manufactures, variant
I thought it should work like that but I can't find manufacturer, variant/variant-images?
Or shall the variant lists togehter with the other products, like under product_name?
Or shall the variant has it own column?
I can see the manufacturer_id but not the name of manufaturer.
Shall it be possible to export/see the name of manufacturers in the csv-file?
Now the CSV-file has the following columns:
product_id
product_parent_id
product_name
product_description
product_quantity
product_code
product_published
product_hit
product_created
product_sale_start
product_sale_end
product_delay_id
product_tax_id
product_type
product_vendor_id
product_manufacturer_id
product_url
product_weight
product_keywords
product_weight_unit
product_modified
product_meta_description
product_dimension_unit
product_width
product_length
product_height
product_max_per_order
product_access
product_group_after_purchase
product_min_per_order
product_contact
product_last_seen_date
product_sales
product_waitlist
product_layout
parent_category
categories_image
categories
price_value
price_currency_id
price_min_quantity price_access
files
images
related
options
followed by several info(like productsnames) in the following columns first row(A-row in excel)...
product_id
product_parent_id
product_name
product_description
product_quantity
product_code
product_published
product_hit
product_created
product_sale_start
product_sale_end
product_delay_id
product_tax_id
product_type
product_vendor_id
product_url
product_weight
product_keywords
product_weight_unit
product_modified
product_width
product_length
product_height
product_access
product_contact
product_sales
product_waitlist
product_layout
parent_category
categories_image
categories
price_value
price_currency_id
files
images
related
options
14 years 5 months ago #51813
In the product_manufacturer_id column, you get the id of the manufacturer.
Variants are added as extra lines: one line for the main product, one line for each of its variants.
If you want to have the name instead of the id of the manufacturer, you will have to edit the file "export" of the view "product" of your back end template via the menu Display>Views. There change:
echo '"'.str_replace('"','""',$product->$column).'"'.$separator;
if($column == 'product_manufacturer_id'){
$categoryClass = hikashop_get('class.category');
$category = $categoryClass->get($product->$column);
echo '"'.str_replace('"','""',$category->category_name).'"'.$separator;
}else{
}else{
- Micke_skane
14 years 5 months ago - 14 years 5 months ago #51862
by Micke_skane
Ok, I'll change the code so that the name are exported instead.
Why is this kind of changes something that shall be done manual instead of a "quick" choose/configuration in admin-part?
How about the productprice, is it possible the export annual price with discount?
Last edit: 14 years 5 months ago by Micke_skane.
14 years 5 months ago #51865
Because everyone wants to do something different.
Some wants to remove columns, others wants different things in some of the columns, other formats, etc.
You can't have options for all the possible cases.
It's not possible to export the products price with discounts added.
- Micke_skane
14 years 5 months ago - 14 years 5 months ago #51881
by Micke_skane
Is there a plugin or something if I want to export prices with discount too websites that list/compare products that customers search for from several vendors?
Is this something that can be programmed if theres not a plugin for export a pricefile with productprice with discount?
I've changed the code you suggested but it still export the ID in product_manufactorer_id and Not the name.
The code looks like this:
Have edit the code under my template and product/export.php!
foreach($products_columns as $column){
/*Här skrivs enbart tillverkar-ID ut*/
/*echo '"'.str_replace('"','""',$product->$column).'"'.$separator;*/
/*Här skrivs tillverkarnamnet ut*/
}else{
/* Slut på utskrift av tillverkarnamn*/
14 years 5 months ago #51938
We do it for the google products plugin and for the RSS/Atom feeds.
You could potentially use these to generate exports but the format is XML not CSV.
The google products plugin is in the folder plugins/hikashop and the RSS/Atom feeds are generated with the components/com_hikashop/views/product/view.feed.php file.
That modification looks fine. Are you sure that you are editing the correct file ? If you add a
exit;
line of code, does that stops the processing ?
exit;
