[SOLVED]Product weights for variants showing wrong
14 years 5 months ago - 14 years 5 months ago #51909
by rikatos
[SOLVED]Product weights for variants showing wrong was created by rikatos
On my site I have just noticed that the product weights are showing incorrectly. The main product, and the 4 products on the below link are set to 10kg for main, 10kg for first 2 and 11kg for 3rd and 4th product. Spookily 3rd and 4th product are showing correct weight, but 1st and 2nd are not, and also default isnt. It is show 1kg rather than 10kg for these :
oceansafety.com/leisure/product/738-jonb...recovery-module.html
Any ideas. I have checked and saved each variant.
Last edit: 14 years 5 months ago by rikatos.
14 years 5 months ago #51967
Replied by nicolas on topic Re: Product weights for variants showing incorrectly
Edit the files show and show_block_dimensions of the product view via Display->views and change all the pieces of code:
,'0'),',.')
,',.'),'0')
That should fix the problem.
,'0'),',.')
,',.'),'0')
The following user(s) said Thank You: rikatos
14 years 5 months ago - 14 years 5 months ago #52012
by rikatos
Replied by rikatos on topic Re: Product weights for variants showing incorrectly
I must be doing something wrong in product show there isnt exactly that variation, in the other there is but it makes little difference
Its ok worked it out ! yayy!, it was slightly different in the show file, but sorted it anyway and now all is great once again:) thanks for help.
