problem with wishlists
- sandra1964
13 years 10 months ago #82445
by sandra1964
problem with wishlists was created by sandra1964
I have a problem with the wishlist ... if I add a product to the list on the back end does not display the name nor the price. What can I do? If I reinstall the latest update of Hikashop lose data relating to products?
thanks
Sandra
thanks
Sandra
13 years 10 months ago #82535
by Xavier
Replied by Xavier on topic problem with wishlists
No you can try to install the latest update from our website, you will not lose data related on products.
Don't forget to make a backup.
- sandra1964
13 years 10 months ago #82547
by sandra1964
Replied by sandra1964 on topic problem with wishlists
I reinstalled version 2.0 but wish lists in the back end can not display products included, which would be displayed correctly on the front end...
13 years 10 months ago #82637
by Xavier
Could you give us a backend and a ftp access ?
- sandra1964
13 years 10 months ago #82644
by sandra1964
Hi Xavier,
my client would prefer not to provide data access ... can you give me directions to make the necessary checks?
13 years 10 months ago #82714
by Xavier
No problem, you have to check in the view "cart / form" which values are returned, then go in "adminstrators/components/com_hikashop/views/cart/view.html.php" to see how the data is taken.
And maybe check in the file "adminstrators/components/com_hikashop/classes/cart.php" if one of the function is used to get the products in the wishlist, or maybe in the class "order.php".
- sandra1964
13 years 10 months ago #82803
by sandra1964
Hi Xavier,
I send you the file and the folder com_hikashop cart / form because I can not figure out if there is something wrong. I hope you will help me because my client absolutely wants wishlist...
Thank you
sandra
Thank you
sandra
13 years 10 months ago #82959
by Xavier
I can't install this package, it returns an error. And I don't really have time to unzip, then copy all my files (and it will certainly returns error when displaying website).
Besides I can't reproduce the problem on my end, it's actually working fine.
What kind of product are you trying to add in the wishlist, main product, variant, product with options ?
- sandra1964
13 years 10 months ago #82997
by sandra1964
doing more testing I noticed that the error occurs when I insert in the wishlist variants of a product. I also wonder where and how I can activate the "notify me" button when the product is "out of stock"?
Thank's
Thank's
13 years 10 months ago #83088
by Xavier
Can you tried to create en order in the backend, then add a variant and tell us if it's working fine for the orders ?
To activate the "Notify me" you have to enable the waitlist feature in HikaShop > Configuration > Display.
- sandra1964
13 years 10 months ago #83099
by sandra1964
Hi Xavier,
I did other tests and I noticed that errors occur when the product variants not specified the price and name. Now I have given to each variant the price and the name and it seems to work.
However, there is another thing that does not work as it should ... my products is associated with a size (S - M - L) but to choose the S, which is the size that appears at the beginning, I'm forced to choose the M or L and then click S otherwise in the cart or in the wishlist is inserted size M
13 years 10 months ago #83917
Replied by nicolas on topic problem with wishlists
Sorry for the delay, we were in holidays.
Could you provide a link to the page where you have that characteristic issue so that we can see what's going on ? From what you're saying, it seems that you have a javascript error on page load resulting in the initial javascript of HikaShop not being run and thus that would explain why you need to change the selection before the add to cart is correctly inserted. And we would need to look at the HTML/javascript of the page with firebug on your website in order to look at it and confirm or infirm the issue and look for the cause of the error and for a solution.
