Shopping Cart (module) generating too many links
15 years 1 week ago #25685 by vasjaf
Hi Nicolas
I use AceSEF and HikaShop generates too much links.
I found out that Shopping Cart (module) for example generates a link depending where you are.
For example if you are in www.site.com/article , when you click the price link of Shopping Cart Module you get www.site.com/article/checkout
Let say if you are in www.site.com/about_company , when you click the price link of Shopping Cart Module you get in www.site.com/about_company/checkout
Is it possible to do so that wherever you are when you click the cart link you get www.site.com/checkout
15 years 1 week ago #25687 by nicolas
Yes, that's possible. You need to set the option "force menu on checkout" of the config so that from wherever you come, you're always redirected to the same URL.
14 years 9 months ago #33135 by jouwnaambord.nl
"Is it possible to do so that wherever you are when you click the cart link you get www.site.com/checkout "
I found this answer that partially answers my question. I wonder if it's possible to link to www.site2.com/checkout , i.o.w. redirect to a second URL?
B.R.
Michel Pouli
14 years 9 months ago #33161 by nicolas
No that's not possible without the redirect.
14 years 9 months ago #33164 by jouwnaambord.nl
Hi Nocolas,
Thanks. But what do you mean by that? That it is possible with a redirect? Where to make this redirect?
Michel.
14 years 9 months ago #33167 by nicolas
It's it's possible with a redirect as I explained above.
First, you will have to create a hikashop checkout link in the joomla menu manager. So you will be able to have the URL www.site.com/checkout
Then, you can set the id of that menu in the option "force menu on checkout" of the config so that the checkout uses that URL.
I see that you're you're talking about a site2.com ? Do you mean that you would like to have the cart copied from one website to another ? If so, that's not possible.
14 years 9 months ago #33177 by jouwnaambord.nl
Well, not exactly copied, but I want to use the Plug-in "Joomla Multi Sites" and share the Hikashop between two or three different slave sites (the sharing of Hikashop is possible in this plug-in). But the checkout has to be through one SSL mastersite. That means I have to redirect on Checkout from http://www.slavesite_a.com to www.mastersite.com .
14 years 9 months ago #33202 by nicolas
So the question should be asked to JMS :)
If the hikashop tables are common to all your websites, then yes, you will have the same cart on all websites and you should just put a link to go to the master website. But I don't know how JMS has done the integration with HikaShop so I can't tell you for sure.
Time to create page: 0.184 seconds
