- Thank you received: 1
Bug rating & problem with compare
14 years 1 month ago #69866
by fdesanto
Bug rating & problem with compare was created by fdesanto
Bug rating:
in the product listing div, if i show the votes and hide the button "add to chart" the rating don't work(javascript error)
Problem with Compare product
You can not compare the products on different pages
Bug rating:
14 years 4 weeks ago #70034
Replied by nicolas on topic Re: Bug rating & problem with compare
1. What is the javascript error you have ?
2. Yes, that's note supported for now.
14 years 4 weeks ago #70062
by fdesanto
Replied by fdesanto on topic Re: Bug rating & problem with compare
Uncaught ReferenceError: Class is not defined vote.js:1
Uncaught TypeError: undefined is not a function 12-cat1.html:1011
if the add to chart button is displayed, work well
14 years 4 weeks ago #70066
by fdesanto
I investigated:
if the chart button is displayed the html head code is
if the chart button is hidden is
The mootool scripts are loaded after vote.js, this causes an error
<script src="/media/com_hikashop/js/hikashop.js?v=160" type="text/javascript"></script>
<script src="/media/system/js/mootools-core.js" type="text/javascript"></script>
<script src="/media/system/js/core.js" type="text/javascript"></script>
<script src="/media/system/js/mootools-more.js" type="text/javascript"></script>
<script src="/media/com_hikashop/js/vote.js" type="text/javascript"></script>
14 years 4 weeks ago #70068
by fdesanto
I solved so:
in com_hikashop/views/vote/view.html.php at line 217 i move $doc->addScript(HIKASHOP_JS.'vote.js'); after $class->loadJS();
14 years 4 weeks ago #70084
by Xavier
Replied by Xavier on topic Re: Bug rating & problem with compare
Hi fdesanto,
Thanks to have shared your solution. I will correct it on our end for the next release.
