- Thank you received: 1
[SOLVED] Frontend Invoice Print Issue - IE9
- manjeshmohan
14 years 3 weeks ago - 14 years 2 days ago #70518
by manjeshmohan
[SOLVED] Frontend Invoice Print Issue - IE9 was created by manjeshmohan
When I click on the frontend print button, the page is trying to get the print box but it gets closed all of a sudden and be in the same page itself in IE9.
The same is fine for Google Chrome, Firefox and Safari.
Please check the same.
Thanks & Regards,
Manjesh.
Thanks & Regards,
Manjesh.
Last edit: 14 years 2 days ago by manjeshmohan.
14 years 3 weeks ago #70746
Replied by nicolas on topic Re: Frontend Invoice Print Issue - IE9
We tried on our end and it's working on some websites and not on others with IE.
It seems to be a timeout issue.
Try to change the line:
$js = "window.addEvent('domready', function() {window.focus();window.print();setTimeout(function(){try{ window.top.document.getElementById('sbox-window').close(); }catch(err){ window.top.SqueezeBox.close(); }}, 1000);});";
$js = "window.addEvent('domready', function() {setTimeout(function(){window.focus();window.print();setTimeout(function(){try{ window.top.document.getElementById('sbox-window').close(); }catch(err){ window.top.SqueezeBox.close(); }}, 1000);},1000);});";
and that should solve the problem.
- manjeshmohan
14 years 3 weeks ago #70833
by manjeshmohan
Replied by manjeshmohan on topic Re: Frontend Invoice Print Issue - IE9
Tried the same and found to be unsuccessful.
When I tried to refresh the page, I'm getting the print window.
I also tried to increase the value '1000', but of no use that the print window is not popping up just like in other browsers.
Manjesh.
Manjesh.
14 years 3 weeks ago #70967
That modification has solved it on our end.
We made the modification on our demo website and it's now working there for IE9.
I forgot to say in my last message but that code modification should be done in the file components/com_hikashop/views/order/view.html.php
The following user(s) said Thank You: manjeshmohan
- manjeshmohan
14 years 3 weeks ago #71023
by manjeshmohan
Solved now.
I changed the same in the views->printcart, that's why it was not working out.
Manjesh.
Manjesh.
