changing "à l'unité" and problem with position
9 years 7 months ago #267969 by anouk3177
-- Joomla version -- : 3.6.5
i would like to change "à l'unité" for "les trois" just for one product, is it possible ?
i have another question :
when i m on the list of product the position with a diaporama of photos is on the right as i want but when i m on the poruct itself the photos of the diaporamas is going down ? how come ?
Thanks for your reply^^
9 years 7 months ago #268008 by Jerome
1 - Such thing is possible but would require some customization.
If you want to change that only for specific products ; best would be to use a product custom field so you can then determine if you want to display the classical translation or a specific translation.
Then, thanks to view override, you can change there the "PER_UNIT" translation is display and read the product custom field to determine which text you want to display.
2 - I'm sorry but I don't understand what you want to do.
9 years 7 months ago #268013 by anouk3177
thanks
when you are on the list of product for exemple "manager" there is photos on the right
problem is when you are in one product only the photos are going down not on the right anymore
9 years 7 months ago #268030 by nicolas
The issue is that the right sidebar HTML is outside of the layout structure on the product page:
monosnap.com/file/3A7kgkW3JnNNSFqjozlXzqNWT4YfR7
On the left of the screenshot (the listing), the sp-right div is just after the sp-(none) one (for the main content). But on the right (the product page), the sp-right is completely outside the structure and that lead to the display problem you're talking about.
Two possible things:
- either there is a problem with the way the template handles the right sidebar in some cases.
- the product page has been customized and there are some </div> tags missing in these customized layout pushing the sidebar out of the structure of the template.
To verify that, switch to the default template of Joomla temporarily and you should have the module displaying on the side on the listing and on the product page in the same manner.
9 years 7 months ago #268060 by anouk3177
Well i don t know how to fix it
look on the same template (with a free version of hikashop) it s working well
www.ek-kinox.com/NewSite/index.php?optio...e=cabbage&Itemid=215
i didn t touch anything on the html code
9 years 7 months ago #268062 by anouk3177
it s exactly the same position : right
everything is the same
9 years 7 months ago #268063 by anouk3177
do i have to reinstall hikashop ?
9 years 7 months ago #268084 by Mohamed Thelji
I don't think that re-installing Hikashop will help, if you don't have any customization of files of the "product" view of your front-end template via "Hikashop->Display->Views". Then your issue is probably related to your template so you should probably contact your template provider or directly check the code of that template.
9 years 7 months ago #268117 by anouk3177
i have to fix the problem at this part views but wich files it s i l check ?
9 years 7 months ago - 9 years 7 months ago #268123 by Philip
you will find your template file in your website root file :
Go in YourWebSite/templates/TemplateName.
Last edit: 9 years 7 months ago by Philip.
