Activation Problem
15 years 8 months ago #9965
by rohit007
Activation Problem was created by rohit007
There are 2 big problem with activation of new users.
First of all can you tell me how to show the activation message on registering.
And please try to correct it in your next version.
2nd is if a user is not activated and he/she login then it doesn't show any error and retrieve a wrong address of some other users this is a very serious bug i think.
Hikashop is an awesome service so please try to solve these 2 problems i have mentioned.
15 years 8 months ago #9968
Replied by nicolas on topic Re: Activation Problem
1. That is not a problem in HikaShop but in your template: www.hikashop.com/en/support/documentatio...tibility-issues.html
2. That's indeed a bug that no one reported yet. It seems that the login function of joomla does not return an error in such case which is why hikashop believes that the login was successful. You can edit the file components/com_hikashop/controllers/checkout.php and change the code:
if(JError::isError($error)){
by:
$user =& JFactory::getUser();
if(JError::isError($error) || $user->guest){
That should fix the problem.
by:
15 years 8 months ago #9981
by rohit007
Replied by rohit007 on topic Re: Activation Problem
Thank you so much!!
The problem has been solved out. Keep doing the good work!!
you guys rock!!! \m/
