My (workaround) for an inventory backorder system
13 years 11 months ago #80961 by karlvann
I really needed this function and I have no idea how to code, I found a simple solution that I wanted to share just in case anybody else was in the same situation.
First, I added 1000 to my all of my inventory. this way, if it says 1023, I know I have 23 available.
Second, I found this line, I had no idea what I was doing but it worked, I added "-1000" after product quantity. This way my front end displays the product inventory -1000, which is the real inventory.
class="hikashop_product_stock_count">'.JText::sprintf('X_ITEMS_IN_STOCK',$this->row->product_quantity-1000).'</span><br/>';
In the following link it explains how to add some code to notify the customers if there is less than a certain quantity.
www.hikashop.com/en/forum/search.html?q=...antity&childforums=1
Here is the code after I changed it.
if($this->row->product_quantity<1001)
echo '<span class="hikashop_product_stock_count">'.JText::_('This size/colour is on backorder so it might take around ten days for delivery').'</span><br/>';
I added the <1001 here, and my backorder message. This way as soon as the item reaches 0, it informs the customer of a longer waiting time, this is where my plan takes effect. Customers can order with the knowledge that it will take a bit longer due to the item not being in stock.
The only negative effect I can see here is that my inventory has plus 1000 products, But this doesn't bother me at all.
9 years 11 months ago #257619 by montemama
Hi, could you, please, advise where to find and change mentioned codes? I cannot find it and the link doesn´t work.
Thank you!
9 years 11 months ago #257620 by nicolas
The code evloved a bit since then. It's the file "quantity" of the view "product" that you want to edit via the menu Display>Views.
The cod eto change is now:
if($this->row->product_quantity == 1 && JText::_('X_ITEM_IN_STOCK') != 'X_ITEM_IN_STOCK') $text = JText::sprintf('X_ITEM_IN_STOCK', $this->row->product_quantity); else $text = JText::sprintf('X_ITEMS_IN_STOCK', $this->row->product_quantity); echo '<span class="hikashop_product_stock_count">'.$text.'<br/></span>';
The following user(s) said Thank You: montemama
9 years 10 months ago #259536 by montemama
is it possible to use in stock checkbox filter with this "+1000 quantity" hack?
Where and how do I need to customize the code?
Thanks in advance for your help.
9 years 10 months ago #259538 by nicolas
No. You'll have to customize the file administrator/components/com_hikashop/classes/filter.php
and change the code:
if($filter->filter_type=='instockcheckbox' && $infoGet[0]=='in_stock'){ $filters[]=' b.product_quantity!=0 '; }
if($filter->filter_type=='instockcheckbox' && $infoGet[0]=='in_stock'){ $filters[]=' (b.product_quantity==-1 OR b.product_quantity<=1000 ) '; }
9 years 10 months ago #259560 by montemama
thank you for your effort, but when I use it, I get this error in frontend.
Error is still there also when I use the originial piece of code. I had to unpublish the filter and e-shop works again.
Any ideas why?
9 years 10 months ago #259588 by nicolas
Try adding the code:
function getFieldToLoad($filter, $divName, &$parent){ return ''; }
after the line:
class hikashopInStockCheckboxClass extends hikashopFilterTypeClass{
in the file administrator/components/com_hikashop/classes/filter.php
That should fix the problem.
9 years 10 months ago #259628 by montemama
Error is gone, but the filter doesn´t work :(
9 years 10 months ago #259657 by nicolas
Then could you provide a screenshot of the settings of your filter and a link to the page where we can try it ?
9 years 10 months ago - 9 years 10 months ago #259671 by montemama
Here is the filter setting.
You can try the result here: montemama.eu/index.php/eshop
I tried to select"product category" in fileld Categories.
but, I got this error in frontend when I used the filter
Last edit: 9 years 10 months ago by montemama.
9 years 10 months ago #259673 by nicolas
Change the line:
$filters[]=' (b.product_quantity=-1 OR b.product_quantity<=1000 ) ';
I made a typo in my previous code.
9 years 10 months ago #259721 by montemama
Nicolas, without change. Any other ideas?
9 years 10 months ago #259740 by nicolas
It's not possible that you get the exact same error message if you did that change.
Please provide the new error message you have and check that the code has been modified properly.
9 years 10 months ago #260361 by montemama
there is no error, but the filter doesn´t work. I get a list of all products, but not only those which are on stock, but completely all.
9 years 10 months ago #260362 by nicolas
Ok. Then try with this line of code instead:
$filters[]=' (b.product_quantity=-1 OR b.product_quantity>=1000 ) ';
9 years 10 months ago #260462 by montemama
Without change. Filter still doesn´t work. May I send you admin login in private message? Would you try to check it?
9 years 10 months ago #260467 by nicolas
Yes and please include a link to this thread in your contact message:
9 years 9 months ago #260851 by nicolas
We got the access but we're not able to access to your backend. We're getting the error below:
monosnap.com/file/54PetlwJMPpguC6IHlcTyw0pChNB5H
Could you do something about it ?
9 years 9 months ago #260995 by montemama
could you, please, try it again? I hope I have fixed the problem with access. Please, let me know if it works now. Thank you!
9 years 9 months ago #261102 by Jerome
Unfortunately, it's still the same.
pasteboard.co/t9p8f2hiE.png
