Product search module does not work
16 years 2 weeks ago #1360
by Redeemer
Product search module does not work was created by Redeemer
It seems that searching for products does not yield any results. Product searching worked perfectly in the previous version of Hikashop, but for some reason the search function can't find any of my products in this version.
If someone could help me solve this issue, I would be very happy.
-Redeemer
-Redeemer
16 years 2 weeks ago - 16 years 2 weeks ago #1365
Replied by nicolas on topic Re: Product search module does not work
Is the product search plugin published ?
I see no reason why it wouldn't work on the new version if it worked on the previous.
Last edit: 16 years 2 weeks ago by nicolas.
16 years 2 weeks ago - 16 years 2 weeks ago #1366
by Redeemer
Replied by Redeemer on topic Re: Product search module does not work
Yes, both the category search and product search plugins are published.
This is strange, since the product search plugin worked perfectly before I updated Hikashop...
I'll try disabling and then reenabling the search plugin.
EDIT: Hmm, that didn't work. Do you have any ideas?
Last edit: 16 years 2 weeks ago by Redeemer.
16 years 2 weeks ago #1367
Something you could try is to activate the debug mode of Joomla and look at the queries at the bottom of the page after a search. Look at the ones on the table hikashop_product and see if any of them contains your search string. If not, then the problem lies in the fact that joomla can't trigger the plugin for whatever reason. If yes, then maybe there is an error in the search query in some circumstances ?
16 years 2 weeks ago #1371
by Redeemer
Here's one of the queries Joomla spat out after I performed a search for "ammo" (without the quotes):
It looks to me like Joomla triggered the plugin fine... I can see my search string in there.
SELECT a.product_id AS id, a.product_name AS title, a.product_created AS created , a.product_description AS text, "1" AS browsernav
FROM jos_hikashop_product AS a
WHERE a.product_published=1
AND a.product_type='main'
AND ((a.product_name LIKE '%ammo%')) OR ((a.product_description LIKE '%ammo%'))
ORDER BY a.product_modified DESC
LIMIT 0, 50
16 years 2 weeks ago #1376
The query is good too. I don't see any reasons why it wouldn't work if it goes that far.
16 years 2 weeks ago #1382
by Redeemer
Yes, it's very strange. The products don't show up at all in the results list.
If you guys could look into this matter further, I would be much obliged. Don't worry, I'm prepared to wait.
16 years 2 weeks ago #1384
Sure, but we can't fix something which works for us. The only way we could would be to either be able to reproduce the problem on our test website, or have access to your website (+ FTP). But since we can't do both, we can't look at the problem
16 years 2 weeks ago #1390
by Redeemer
Well, this is embarrassing.
The word I was searching for never brought up any products because that word wasn't in the name or the description of any of my products.
Sorry for wasting so much of your time.
-Redeemer
-Redeemer
16 years 2 weeks ago #1391
Great, at least there is no bug
