Module Class Suffix doesnt work
16 years 4 days ago #2323 by LAS_VEGAS
I added shopping cart module to position 'left'. I set "Module Class Suffix" as "_menu". But on the front end, this setting is not 'respected'. The module is put inside with wrong css class:
<div class="module">...</div>
It should be:
<div class="module_menu">...</div>
This works fine with main menu module for example.
16 years 4 days ago - 16 years 4 days ago #2325 by nicolas
That's interesting.
It actually works on our dev website but doesn't on our demo website. We will have to investigate...
It's actually a parameter which is handled automatically by joomla and since it was working on our dev website, we thought it would be working all the time.
I'll update that thread when we find the problem.
Last edit: 16 years 4 days ago by nicolas.
16 years 4 days ago #2326 by nicolas
You can edit the file modules/mod_hikashop/mod_hikashop.php and the file modules/mod_hikashop_cart/mod_hikashop_cart.php and change in each the code
foreach($module_options as $key => $option){ $params->set($key,$option); }
to
foreach($module_options as $key => $option){ if($key !='moduleclass_sfx'){ $params->set($key,$option); } }
16 years 4 days ago #2329 by LAS_VEGAS
Thanks, that code fixes the problem.
15 years 11 months ago #2675 by reace
is it not better to use a preceeding space for module_suffix rather then '_' as the space should separate the new suffix from the old without losing formatting etc?
Ive not done much work with these as yet .
15 years 11 months ago #2685 by nicolas
If you use a space, that means that the module div will have two classes:
module new_class
But if you user an _, it will only have one class which is different from the default one:
module_new_class
Ususally, I used that option to set the suffix _menu which is defined for the menu module in order to add a chrome around the module when displayed on the left or right columns of the template. That's a standard way of doing it in joomla.
