Inventory and products without pic
15 years 10 months ago #5506 by nina2011
just want to know if you have 2 things before I download your shop.
1. Do you have so that I can split up the inventory list per the different attributes. ie I have 1 product in 5 colors and 5 sizes, can I keep track of what I have left of each color/size and when I need to order new if there is only one total "stocknumber" per product?
2. Can I show to NOT show any pic for my products?
THANK YOU
15 years 10 months ago #5507 by nicolas
1. Yes. You can use the variants/characteristics system for that:
www.hikashop.com/support/documentation/i...html#characteristics
Stocks can be handled on a per variant basis. However, there is no "total stock" for a product. You will have to add the stock of each variant of your product to know that. That could be something easy to add by tweaking the hikashop views if you know PHP.
2. In the configuration under the tab files, you can remove the default image so that products without image won't display nothing.
