Characteristic values order
15 years 8 months ago #11921
by Galassi
Characteristic values order was created by Galassi
15 years 8 months ago #11930
Replied by nicolas on topic Re: Characteristic values order
In the config under the tab "display" you have the option "Characteristics values ordering" where you can choose to order them by ID or by alphabetic order.
15 years 8 months ago #11939
by Galassi
Replied by Galassi on topic Re: Characteristic values order
the recommended setting is already set to ID.
I note that in the frontend the various values are properly ordered.
In the backend are not properly sorted.
As shown in the image attached to the previous message.
15 years 8 months ago #11944
Ah yes, in that view there is no ordering done. Is that a problem ?
You can change the line:
$query = 'SELECT * FROM '.hikashop::table('characteristic').' WHERE characteristic_parent_id = '.$characteristic_id;
by:
$config =& hikashop::config();
if($config->get('characteristics_values_sorting')=='old'){
$order = 'characteristic_id ASC';
}else{
$order = 'characteristic_value ASC';
$query = 'SELECT * FROM '.hikashop::table('characteristic').' WHERE characteristic_parent_id = '.$characteristic_id.' ORDER BY '.$order;
in the file administrator/components/com_hikashop/views/characteristics/view.html.php in order to get it ordered.
by:
}else{
15 years 7 months ago #14591
by davcraiguk
David Craig
Hikashop 1.5.0 Business edition
www.charitycanvasprints.com
Replied by davcraiguk on topic Re: Characteristic values order
Having to change the core to do a sort, especially in the product variant listing, is surely not the best way.
Most lists in Joomla it is possible to click on the column headings to do a sort.
This would be really useful for me (and others I am sure) where I have multiple variant products, i.e 5 sizes and a 3 choices of colour for each size, thats 15 variant products.
does it take much coding to implement this, where you have a choice of which column you can sort on like you have on the main products listing page?
Like in the main products listing:
It means its much easier to maintain the variants e.g prices etc.
<a title="Click to sort by this column" href="javascript:tableOrdering('b.product_name','desc','');">Name</a>
David Craig
15 years 7 months ago #14623
That modification has been integrated in the latest version of HikaShop so no need to hack the core to have your values sorted by name there.
There is no point in sorting variants. Variants are combinations of values of characteristics. Sorting the values of the characteristics is what need to be done and it's already in the todo list.
We don't have the time to do all the features everyone is asking. HikaShop's code is open. If you want it help yourself. We will be happy to integrate the changes in HikaShop if they are done correctly.
