Problem with "Please create or select an address"
15 years 7 months ago - 15 years 7 months ago #13727 by banner05
I've been trying very hard to get this to work but to no avail.. Can any help me with regard to getting an "address" table to come up during the order process. The site is www.easyfitness.ie
Last edit: 15 years 7 months ago by banner05. Reason: spelling
15 years 7 months ago #13741 by nicolas
As explained in the documentation, you can't have the address view without the login view before in your checkout workflow.
15 years 7 months ago #13751 by banner05
I also tried that but I get the following with no table to fill in to create new account... See Pic
15 years 7 months ago #13753 by nicolas
That's because you deactivated the user account creation in joomla. You also turned off the login option in the config under the tab checkout.
15 years 7 months ago #13756 by banner05
Forgive my ignorance as I am very new to joomla but where do I activate the user account creation
Thanks for the info so far much appreciated..
15 years 7 months ago #13760 by nicolas
On Joomla 1.5, there is an option in the configuration of joomla.
On Joomla 1.6, it is located in the options of the user manager.
15 years 7 months ago #13762 by banner05
Just sorted problem ... Thanks again for the help.
Bye
14 years 4 months ago #58614 by sugrit
What I'm going to develop is selling members detail.
and so no need for billing/shipping address or anything other. Just "buy contact" then select payment method and then payment confirmation and back to member detail page to see member's detail.
So i have hide all registration and login things. However it is asking me
Any solution?
14 years 4 months ago #58622 by Mohamed Thelji
I think that you'll probably find your answer there :
If you want to have a checkout without registration but with address, you will have to have both "login" and "address" views in the checkout workflow. Then, in the Checkout tab of the configuration, you can change the option "registration" to "no registration" in order to remove the creation of a user account. Also, you can turn off the "login" option there to remove the login area of the checkout.
That way, you will still have the address form but no user account would be created.
That "Registration" option is only available in our commercial editions.
14 years 4 months ago #58830 by sugrit
But I cant see create Address field in my checkout process...
I haven't premium version. I'm using free version. So, is there any related version problems?
It is showing me "Please create or select an address" but not showing that field in checkout process. I will manage about registration hide.
Can you tell me where i will be wrong ?
14 years 4 months ago #58876 by nicolas
You probably didn't remove the "address" view from the "checkout workflow" option of the configuration. Do that and it shouldn't bug you with the address.
