Frontend editing of products
15 years 7 months ago #14166 by kiwi2b
Hi there, just finding out about HikaShop. Hoping for a feature that allows the shop owner to edit the products from the frontend, to make it easy for them. I'm thinking of the price and description, maybe the image. Even adding a new product. Is this possible / can it be added?
Thanks for your extension.
15 years 7 months ago #14170 by nicolas
There is no option for that for now in HikaShop. It's already in the todo list.
15 years 7 months ago - 15 years 7 months ago #14213 by kiwi2b
Thanks for the quick reply. Any idea on time for this? Do you have a link for what you plan to add?
Last edit: 15 years 7 months ago by kiwi2b.
15 years 7 months ago #14214 by nicolas
We didn't start yet and we are working on other things. It won't be before summer.
14 years 2 months ago #65544 by adambako
hello.
im also looking forward to edit product and orders from frontend..
1year 5months ago you wrote its on your to-do list..
how its look now?
thanks
14 years 2 months ago #65737 by nicolas
There are hundreds of things on our todo list. We can't do everything at the same time.
We've worked hard on that in the past few months and we will have that available before the end of the year.
12 years 4 months ago #165559 by theguy
Will this feature be available in the near future?
Guy.
12 years 4 months ago #165560 by Jerome
Since September 2012, a lot of things changed.
Like HikaMarket : www.hikashop.com/extensions/hikamarket-front-end.html
12 years 4 months ago #165561 by theguy
Thank you ;)
