Problem with "magic tabs" in Product description.
15 years 2 weeks ago - 15 years 2 weeks ago #29658 by sokartch
I use "Magic Tabs" with "Core Design Scriptegrator plugin", all commercial versions and up to date.
If I use {magictabs}24:25:26{/magictabs} in Articles it shows tabs
(24, 25 and 26 are ID's from existing Articles).
But if I use it in the Product description the I got following error message:
Fatal error: Call to a member function setState() on a non-object in
/home/sokartch/public_html/cms/plugins/content/cdmagictabs/cdmagictabs.php on line 576
I try it with few templates...
Info:
Following, if inserteg in the Product description, shows the tabs!
{magictabs}
TAB 01::Lorem ipsum dolor.
TAB 02::Lorem ipsum dolor sit.
TAB 03::Lorem ipsum dolor sit amet.
{/magictabs}
Thank you in advance!
Last edit: 15 years 2 weeks ago by sokartch.
15 years 2 weeks ago #29680 by nicolas
That's a problem in the magic tabs plugin which can only handle articles display in articles based on the way it's done.
You should try to find another plugin for that, or not use article ids and directly write your text in the product description.
15 years 2 weeks ago - 15 years 2 weeks ago #29684 by Wowakan
Give me a link to your website. I am using Magic-tabs with no problem. I will try to take a look and see what you are doing wrong. Here is a link to my website so you can see what it is suppose to look like. :)
Take a look
"It is by Caffeine alone that I set my mind in motion. It is by the Beans of Java, that my thoughts acquire speed. The hands acquire shakes; the shakes become a warning. It is by Caffeine alone that I set my mind in motion.
RedTalkers Web Design, Development, SEO
Last edit: 15 years 2 weeks ago by Wowakan.
15 years 2 weeks ago #29704 by nicolas
Wow, that's great. It's a good news then !
15 years 2 weeks ago - 15 years 2 weeks ago #29749 by sokartch
There is nearly nothing to see on front end... site isn't active and I learn HikaShop options...
Magic Tab function:
function getItem($aid = 0)
$application = JFactory::getApplication();
jimport('joomla.application.component.model');
$model = JModel::getInstance('Articles', 'ContentModel', array('ignore_request' => true));
$params = $application->getParams();
echo $params;
$model->setState('params', $params); /* ERROR */
$params values in OK case (for first tab):
{"article_layout":"_:default","show_title":"0","link_titles":"0","show_intro":"0","show_category":"0","link_category":"0","show_parent_category":"0","link_parent_category":"0","show_author":"0","link_author":"0","show_create_date":"0","show_modify_date":"0","show_publish_date":"0","show_item_navigation":"0","show_vote":"0","show_readmore":"1","show_readmore_title":"1","readmore_limit":"100","show_icons":"1","show_print_icon":"1","show_email_icon":"1","show_hits":"0","show_noauth":"0","category_layout":"_:blog","show_category_title":"0","show_description":"0","show_description_image":"0","maxLevel":"1","show_empty_categories":"0","show_no_articles":"1","show_subcat_desc":"1","show_cat_num_articles":"0","show_base_description":"1","maxLevelcat":"-1","show_empty_categories_cat":"0","show_subcat_desc_cat":"1","show_cat_num_articles_cat":"1","num_leading_articles":"1","num_intro_articles":"4","num_columns":"2","num_links":"4","multi_column_order":"1","show_subcategory_content":"0","show_pagination_limit":"1","filter_field":"hide","show_headings":"1","list_show_date":"0","date_format":"","list_show_hits":"1","list_show_author":"1","orderby_pri":"order","orderby_sec":"front","order_date":"published","show_pagination":"2","show_pagination_results":"1","show_feed_link":"1","feed_summary":"0","filters":{"1":{"filter_type":"BL","filter_tags":"","filter_attributes":""},"6":{"filter_type":"BL","filter_tags":"","filter_attributes":""},"7":{"filter_type":"BL","filter_tags":"","filter_attributes":""},"2":{"filter_type":"BL","filter_tags":"","filter_attributes":""},"3":{"filter_type":"BL","filter_tags":"","filter_attributes":""},"4":{"filter_type":"BL","filter_tags":"","filter_attributes":""},"5":{"filter_type":"BL","filter_tags":"","filter_attributes":""},"8":{"filter_type":"BL","filter_tags":"","filter_attributes":""}},"featured_categories":[""],"layout_type":"blog","menu_text":1,"page_title":"SokART 2D & 3D Gravuren","show_page_heading":0,"menu-meta_description":"sfgsdfgds","menu-meta_keywords":"sgfdgds","secure":0,"page_description":"SokArt 2D & 3D Gravuren","page_rights":""}
$params value in ERROR case (for first tab):
{"menu_text":1,"show_page_heading":0,"secure":0,"page_title":"e-Shop","page_description":"SokArt 2D & 3D Gravuren","page_rights":""}
BR PR
15 years 2 weeks ago #29752 by nicolas
The problem is not with $params but with $model which is not created by the function JModel::getInstance
Maybe you could try to add the line:
JModel::addIncludePath(JPATH_BASE.DS.'components'.DS.'com_content'.DS.'models');
before that function call so that it loads the model from com_content and not com_hikashop (the code is a wild guess so it might not work).
15 years 2 weeks ago #29754 by sokartch
Wau, it's now running.
Congratulation!!!
BR PR
15 years 2 weeks ago #29761 by nicolas
Then that's something which should be reported back to magic tabs so that they include it in their next version. That will allow a greater compatibility with HikaShop and other extensions.
