Bug in Generate products function
14 years 10 months ago #36769
by Margot
Bug in Generate products function was created by Margot
Thanks for your help in using this function - I got it to work.
I have found a bug. When I have more than a few files or images (than the 5 or so that I was accidentally generating) in the folder and click on 'Import' the screen goes to the IE message: Page cannot be presented.
I had around 20 jpeg files in the folder. The size of the ones I imported as files was around 6 mb, the ones I imported as images were 60 kb.
I then use the back button, or close the tab and re-open my Joomla admin to navigate to the products which are there and work perfectly.
14 years 10 months ago #36877
Replied by nicolas on topic Re: Bug in Generate products function
If you configured HikaShop to resize your full size images in the Files tab of the configuration, HikaShop will have to load each image in memory in order to resize it. That can eat a lot of resources when you start to have a lot of them, up until the limit your hosting company set to your website in the server configuration.
You should either:
Not set an "image width/height" in the configuration so that the images are not resized when imported
And/or import less images at once
And/or ask your hosting company to increase your resources limitations (memory_limit and max_execution_timeout settings)
You should either:
14 years 10 months ago #36974
by Margot
Replied by Margot on topic Re: Bug in Generate products function
Thank you again!!
