- Thank you received: 1
UPS Shipping not avaible on Checkout
14 years 6 months ago #50152
by R_Fey
UPS Shipping not avaible on Checkout was created by R_Fey
I've been trying to set up UPS shipping for a while now but on the Checkout it is never avaible.
1) set up the payment mehtods and selected UPS Shipping on all of them
2) Published UPS Shipping mehtod
3) No zone restrictions made
4) set up the following settings (system and ups plugin): (see attachment)
Kind regards,
Ralf.
Kind regards,
Ralf.
- Thank you received: 1778
14 years 6 months ago #50215
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: UPS Shipping not avaible on Checkout
Hello Ralf,
Did you also test it with others "Shipping services" like Trade Direct Air (ALL) for exemple ?
14 years 6 months ago #50269
by R_Fey
Replied by R_Fey on topic Re: UPS Shipping not avaible on Checkout
Yes, the AUSTRALIA POST plugin works fine. Just published it and it was visible (almost same settings, no zones declard)
14 years 6 months ago #50275
by Mohamed Thelji
Are you selling free products ?
14 years 6 months ago #50373
Replied by nicolas on topic Re: UPS Shipping not avaible on Checkout
Also, make sure that you set a weight AND dimensions in your products as UPS need them in order to calculate the shipping fees.
14 years 6 months ago #50380
by R_Fey
will test that. thought when the force shipping option is marked in the settings, that would be of no meaning.
14 years 6 months ago #50386
The force shipping option is to activate the shipping selection. But then each shipping plugin which is triggered will have to generate its entries. The UPS server requires weight and dimensions. If not present it won't display any shipping methods and display an error message instead.
If you don't see it, it's probably because of your template:
www.hikashop.com/en/support/documentatio...issues.html#messages
