Points and checkout not working
14 years 1 month ago #61699 by Bugger101
Hello!
Im just testing the alpha user points and it generates a coupon, but the shipping fee left over wont go through to the checkout - the page just refreshes, and gives this error: Error, you cannot validate this order.
Am I missing something?
14 years 1 month ago #61805 by nicolas
Could you do a screenshot of the options of the AlphaUserPoints plugin ?
That error means that the partial payment is not activated and that the coupon amount does not cover the order value.
14 years 1 month ago - 14 years 1 month ago #61811 by Bugger101
Thanks Nicolas,
Ahhh, it works now :)
I don't think I have it setup properly.
Also, can I change the wording of the emails in the language file? I had a quick look and couldn't see anything there - I reckon a search function in the language file would be an awesome addition to HS for those with bug eyes :)
Thanks again for your help :)
Last edit: 14 years 1 month ago by Bugger101.
14 years 1 month ago #61944 by nicolas
In the payment area, you should set 1 point = 0.02 AUD
You can change the text of the emails with translation overrides yes.
There is no need for a search function there. There is already one in your browser for that. Just press CTRL+F, enter your text and hit ENTER and you will get the result of the search on the page.
The following user(s) said Thank You: Bugger101
14 years 1 month ago - 14 years 1 month ago #61974 by Bugger101
Thanks Nicolas!
Couple more questions:
- One more question: Is it possible to have manual shipping methods for registered users, and then use Australia post method for wholesalers?
- With alpha user points, how do you stop groups from earning points if they are all registered? I want to stop wholesalers from gaining points.
Thanks! :)
14 years 1 month ago #62051 by nicolas
- Yes. In each shipping method, you have the "access level" area if you're using the Business edition. That area, allows you to restrict shipping methods to user groups.
- In the joomla options of the AlphaUserPoints plugin, you can configure the "access level" for which the plugin is active. That should allow you to do that.
Time to create page: 0.150 seconds
