- Thank you received: 5
checkout workflow problem *solved*
14 years 3 weeks ago - 14 years 3 weeks ago #74628
by reace
checkout workflow problem *solved* was created by reace
Hello again,
I noticed that , there was no checkbox for the 'Terms and Conditions' before proceeding after the login proceedure;
I read the internal help and then appended it like this;
then I proceeded to place an order.. and proceeded to the 'Checkout'
which then presented this error message below;
for some reason it is skipping the login stage (Iam already logged in) and trying to go straight through to the end.
any idea's what I am doing wrong.
it works okish if I put terms before login.. but it looks weird and I would prefer it either at bottom of actual check out page or just after in workflow.
login > check items > terms > end
something like this.
Actually with workflow described I cannot goto the login section at all.. it is skipped. and if I tick the box , it sez ;
login_address_shipping_payment_confirm_coupon_cart_status_fields,end
login_address_shipping_payment_confirm_coupon_cart_status_fields,terms,end
Please accept the terms and conditions before proceeding
Thank you for your purchase.
Last edit: 14 years 3 weeks ago by reace.
14 years 3 weeks ago #74640
Replied by nicolas on topic Re: checkout workflow bug
Your checkout workflow is not correct.
As explained in the documentation the confirm view should always be in the last step before the end step.
If you're already logged in the login/registration form won't display.
You should try with such checkout workflow:
login_address_shipping_payment_fields,confirm_coupon_cart_status_terms,end
14 years 3 weeks ago #74648
by reace
Replied by reace on topic Re: checkout workflow bug
aha thanks Nicolas have been working on this thing for too long lol.
needed a break.. which I just had.
Appreciated.. and I thought that the solution would be simple.. just couldn't find it .
Thank you very much.
