Small problem updating to stable version: 2.0.0 wi
13 years 10 months ago #75153 by dvddvd
Hello:
When I upgrading to version: 2.0.0, I lost the product listing pagination in all categories.
You can only see 20 items.
Attachment screenshot.
Thanks !
13 years 10 months ago - 13 years 10 months ago #75159 by dvddvd
Hello again
When I upgrading to version: 2.0.0, I can not change the status of the orders directly from the screen of orders.
Thanks!
Last edit: 13 years 10 months ago by dvddvd.
13 years 10 months ago #75179 by nicolas
It sounds like this comes from the fact that you're using a custom backend template.
Can you try to switch to the default backend template to see if that works ?
Do you have any javascript errors in the javascript error console of your browser ?
The following user(s) said Thank You: dvddvd
13 years 10 months ago - 13 years 10 months ago #75459 by dvddvd
The second issue "orders"is now fixed.
was caused by a change in the view.
thank you very much Nicolás
About the first problem:
I could not fix it, even changing the template.
in the error console appears, with the default template:
NodeType constants are not available. chrome-extension://lifbcibllhkdhoafpjfnlhfpfgnpldfl/global_constants.js:28
document.location = universidadpopular.es/administrator/inde...product&filter_id=12 chrome-extension://lifbcibllhkdhoafpjfnlhfpfgnpldfl/global_constants.js:29
thanks
13 years 10 months ago #75462 by Cuervo
I just spent half hour with the same problem and found out that it occurs when you squeeze the browser window too much. Try maximizing the window and the navigation will appear at the bottom, if your monitor is wide enough, that is.
13 years 10 months ago #75467 by dvddvd
It is true laptop screen appears on the monitor but no.
thank you very much
13 years 10 months ago #75473 by Cuervo
13 years 10 months ago #75493 by nicolas
Thank you for the feedback. That helped us understand what was going on. It's now fixed on our end and we updated the package with the fix.
13 years 10 months ago #75856 by dvddvd
Hello Nicolás,
In system states, after the update, I can not edit the name of the state.
David
13 years 10 months ago #75864 by nicolas
What happens ?
Could you activate the debug mode option of the joomla configuration and try again ?
13 years 10 months ago #76277 by dvddvd
Hello nicolas,
I attached the debug output of joomla
thnaks
13 years 10 months ago #76419 by nicolas
That doesn't give any information on your problem.
Could you describe what is happening ?
You don't see the name field in the states zones when you edit them via the menu System->Zones ? Or you can't save ?
What happens when you save ?
Do you have an error message ? If so, what is it ?
Does it work for other zones ?
13 years 10 months ago - 13 years 10 months ago #76571 by dvddvd
Hello nicolas:
The field indicated in the attached file is not editable.
I can not change either the name or the description.
If I generate a new state, I can enter either the name or the address.
Sorry for not explaining properly on English and thanks for your answers
13 years 10 months ago #76826 by Jerome
So you're talking about "Order statuses", not "state" (which are countries' states).
You're screenshot display other information which shouldn't be display (like the parent category).
What url do you have for this page ?
How did you arrived to it ? (where did you click ?)
13 years 10 months ago - 13 years 10 months ago #76844 by dvddvd
I refer to "Order statuses"
url: http://.../administrator/index.php?option=com_hikashop&ctrl=category&filter_id=status
13 years 10 months ago #77080 by Jerome
I made a little mistake during my tests.
I have always Joomfish or Falang installed on my local websites and you don't use it.
Order Statuses should not be edited, you can create new one, you can delete but in general, we don't want to gives the possibility to edit it.
When you create an order status, the most important point is to know that, it is a "key" and not a "name".
You can override the name by editing the translation file.
CONFIRMED="confirmed"
CANCELED="canceled"
etc...
Now, if you really want to edit the order statuses, you have to do it directly in the database or by delete/create steps.
One thing important to know is that, all of your order could have a status, this status is a "status key", a string.
If you delete or modify a order status, all of your configuration could be broken and a lot of orders could have a non-valid order status.
That's why order status shouldn't be modified and translation should be use.
When joomfish/falang is used, the key is not touch, but it would provide different translations for the different languages. That's why the interface allow the edition when the plugin is installed.
Best regards,
13 years 10 months ago #77130 by dvddvd
Ok Gerome, thank you very much
13 years 10 months ago #77134 by Jerome
Another user have the same kind of issue and we update the HikaShop package in order to fix one point.
Now when you create a new order status, you can specify a name.
You can re-download HikaShop 2.0 and this problem would be fix.
After that I have to talk with Nicolas about this editable restriction, see what we could do for statuses which are not "official" one. Maybe we can let other statuses editable.
Time to create page: 0.340 seconds
