Can Not Save System Configuration
- fandomfest
14 years 6 days ago #78055
by fandomfest
Can Not Save System Configuration was created by fandomfest
I know this has been posted at least in in the Beta testing thread, but I am getting this in a recently purchased Business version.
I had to up my core memory_limit to 150M to even get it to load.
HikaShop Business 2.0
Joomla! 2.5.8
PHP Version: 5.3.18
Database Version: 5.1.65-cll
Web Server: Apache/2.2.23 (Unix) mod_ssl/2.2.23 OpenSSL/1.0.0-fips mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
How can this be fixed?
Joomla! 2.5.8
PHP Version: 5.3.18
14 years 6 days ago #78070
by Jerome
Replied by Jerome on topic Can Not Save System Configuration
Would it be possible to have an access to your backend in order to make some tests ?
In your screenshot we can't see the bottom of the page so I don't know where the page is cut, if other page works good, etc.
If it is possible to have an access (by private message), it would be great.
Thanks,
Thanks,
- fandomfest
14 years 5 days ago #78185
by fandomfest
Replied by fandomfest on topic Can Not Save System Configuration
Thanks Jerome!
Just sent you the login info. Also, attached is a compiled screenshot of the entire screen for anyone else having a similar problem.
14 years 5 days ago #78186
by Jerome
It's not a memory limitation. I think it's more a buffer limitation.
The configuration page stops during the "acl tab".
I have modified the "config config" view in order to no display this tab and the config is not displayed fine.
After that, I have reactivate the ACL tab and I have comment some options in the ACL tab, the page still displayed fine but if I display all elements, the page break.
The strange thing is that, removing just one element in the ACL tab fix the problem.
There is no error or memory reach problem with the ACL display, by removing one element (and having a good config page), the Joomla debug said that just 17MB has been allocated.
So I think that the config page is too big, it contains too much data for your PHP buffer configuration.
- fandomfest
14 years 5 days ago #78197
by fandomfest
What do I need to do to fix it?
14 years 5 days ago #78212
by Jerome
You should have some PHP errors in your PHP error log.
Theses errors would give more information about the problem and how to fix it.
- fandomfest
14 years 5 days ago - 14 years 5 days ago #78295
by fandomfest
Called the hosting company and they changed 2 settings that fixed it:
PCRE.backtrack_limit from 1million to 10million
PCRE.recursion_limit from 100,000 to 10million
Now everything is running fine (I can save now and the tabs are in order anyway). Is this change normal?
Last edit: 14 years 5 days ago by fandomfest.
- fandomfest
14 years 5 days ago #78301
by fandomfest
14 years 5 days ago #78313
by Xavier
Replied by Xavier on topic Can Not Save System Configuration
This change seems to be normal, glad that it's working fine now.
