- Thank you received: 2
Comment is showing twice following upgrade v2.0.0
13 years 11 months ago #83161
by wynchcote
Comment is showing twice following upgrade v2.0.0 was created by wynchcote
Hi there,
My customer has Business edition and has upgraded to v 2 recently.
Since then the comments box displays 2x on product screens:
Example:
www.chicchildrensfurniture.co.uk/childre...irls-building-blocks
Is this a bug?
I cannot see what else is causing the problem in their installation.
Thanks, Ken
Example:
Is this a bug?
Thanks, Ken
13 years 11 months ago #83163
by wynchcote
Replied by wynchcote on topic Comment is showing twice following upgrade v2.0.0
Please ignore - the display error is related to template override created for previous version.
When the override is disabled there is only one comment box displayed.
Ken
Ken
13 years 11 months ago - 13 years 11 months ago #83215
by wynchcote
OOPS - I NOW SEE WHAT THE PROBLEM WAS.
My assumption that the cause of my problem, namely that the HikaShop release was the issue (1.6 versus 2.0) was incorrect.
My customer choice of HikaShop Package (Starter versus Business) was the cause of my problem.
My customer had previously used Starter HikaShop + my HTML Override for default_product view.
They upgrade to Business HikaShop and this was what broke my html override.
The coding of default_product view in Starter and Business Packages is different.
The two views are clearly not the same and require a different html_override when customising.
What difference have I noticed between the default_product view in each package?
Comments is coded in FREE default_product view.
Comments is NOT coded in Business default_product view.
Where is comments coded in Business version?
No idea!
Ken
No idea!
Ken
Last edit: 13 years 11 months ago by wynchcote.
13 years 11 months ago #83289
by Jerome
Replied by Jerome on topic Comment is showing twice following upgrade v2.0.0
There is no differences in views between our packages and it was never the case.
It is possible that the view has been modified with versions but the views are the same for every packages in order to let the possibility the change the version without problems.
After that, I do not understand the "comments" part.
