Hikashop - gantry framework , problem with main
13 years 11 months ago #83162 by Lourenço
Hello good afternoon
I have a problem with my project. I try the hikashop 2.0.0 using the framework gantry version v4.1.4 and the problem is i need change the the size of the DIV - ".div#hikashop_product_left_part.hikashop_product_left_part" ... how can i edit that...
13 years 11 months ago #83277 by Jerome
In the HikaShop configuration (in the backend : System > Configuration) you have a tab named "Display".
You would find a "CSS" zone where you would be able to edit the HikaShop css file.
By editing this css file, you would create a "custom" file (so you would have to save your configuration in order to use this new file).
Thanks to it, you would be able to change some CSS rules and to add new one.
