Undefined index: field_default
13 years 7 months ago #97710 by SG
I'm trying to make for the first time a Custom Text field for the table order.
This is the message I got when I tried to save it.
Notice: Undefined index: field_default in /home/marcoshp/public_html/site/administrator/components/com_hikashop/classes/field.php on line 904 Notice: Undefined index: field_default in /home/marcoshp/public_html/site/administrator/components/com_hikashop/classes/field.php on line 915
Here is the printscreen of the config window when saved:
Why do I get this message?
Is the field saved correctly or didn't the process get completed by this error/message?
13 years 7 months ago #97755 by Xavier
Thanks for the report. We have corrected it on our end.
Don't worry your custom field is saved correctly.
13 years 7 months ago #97768 by SG
Replied by SG on topic Undefined index: field_default
Hi Xavier.
Thanks for letting me know.
A side question about custom text from the order table.
How can I exactly get the content from that field.
I tried the following and I CAN get the full_price and order_number but NOT the custom text field.
$order_id = $data->order_id; $orderClass = hikashop_get('class.order'); $order = $orderClass->loadFullOrder($order_id,false, false); echo "<br>Order_number: ".$order->order_number; echo "<br>Order_fullprice: ".$order->order_full_price; echo "<br>order_custom: ".$order->customtext_93_13_25_34."<br>"; print_r($order);
When i use print_r I can see most order_ fields but not the custom text field.
Also in the database I can find it under _hikashop_field but NOT in _hikashop_order
The main reason I was trying to use this custom text field was to add custom intro text in the message.
13 years 7 months ago #97774 by nicolas
"custom text" fields are the only ones which don't have any content. It's normal that you don't see it in the database.
That's because their value is the same for all the elements.
If you want to have a different content for different orders, you should use a "textarea" field instead.
13 years 7 months ago #97778 by SG
You are right about that the content stays the same and that it shouldn't be in the order table.
It's logic when you think about it but sometimes my brain get fried when I'm sitting to many hours behind the computer :-)
Since I need to add text in the mail I will use something like echo JText::_('EMAIL_INTRO_MESSAGE');
That way I can also translate it :-)
If you have a better idea, please feel free to advise.
