add zoom to product's image
- Ahmed nasser
13 years 6 months ago - 13 years 6 months ago #101853
by Ahmed nasser
add zoom to product's image was created by Ahmed nasser
Hello
How to add a magnifier or zoom tool to my product's image ,, in modules and description
Last edit: 13 years 6 months ago by Ahmed nasser.
- Thank you received: 1778
13 years 6 months ago #101909
by Mohamed Thelji
Replied by Mohamed Thelji on topic add zoom to product's image
I think that you'll probably find your answer there :
Hope this will help you a little.If LV Image Zoomer is compatible with module anywhere, you will be able to do what you want.
You could use module anywhere to add a tag in order to add the LV Image Zoomer module in your products description.
extensions.joomla.org/extensions/core-en...dWxlIGFueXdoZXJlIjt9
Rapport de modération
