- Thank you received: 1
Problem with product - saying not available
13 years 6 months ago #105741
by Huski
Problem with product - saying not available was created by Huski
Someone just advised me that they can't put a product in the shopping cart. I have tried to replicate it, and it is a product with 3 variants. One of the variants (which they are choosing) is coming up saying that the product is not available.
Nothing has been changed at all in the products - haven't touched in a long time.
The main product and variants have been set to "unlimited" stock with minimum 1 per order.
Why would this product be saying it is not available?
13 years 6 months ago #105780
Replied by nicolas on topic Problem with product - saying not available
Maybe that the variant is not published ?
Or the main product ?
What is the exact message ?
13 years 6 months ago #105836
by Huski
Replied by Huski on topic Problem with product - saying not available
hi Nicolas
If you go here: www.ecomad.com.au/shop-categories/produc.../category_pathway-26
And then just click add to cart you will get the message. Its the first option in the drop down list that is causing the error which you will see.
This has been working fine up until yesterday - nothing has been touched.
One person is clicking it and nothing is adding to the cart, but it does add to the cart when I do it but I do get the error message.
13 years 6 months ago #105839
by terry5578
Replied by terry5578 on topic Problem with product - saying not available
Huski
I had a similar problem - I am pretty sure that is just a warning message. If you refresh the screen the message goes away and the item is still listed in the cart. If you look at that 'small square (less then 350mm)' it does not have a price. I bet when you look at the price in the backend it is just 0. Change the price to 0.00 - then the message will go away. At least it did for me.
13 years 6 months ago #105840
by Huski
Perfect - that fixed it.
Maybe all costs should be defaulted.
Will need to go through a whole bunch of options now and change them.
13 years 6 months ago #105847
It's probably because you have the option "Display add to cart button for free products" turned off and so the system doesn't like that you add a product with a free option. Turn that option off and it should help.
The following user(s) said Thank You: terry5578, leitzdesign
13 years 6 months ago #105958
by terry5578
Thank you Nicolas - this is the correct way to fix this issue.
Time to create page: 0.102 seconds
