Registration in Checkout flow
13 years 5 months ago - 13 years 5 months ago #109782
by Meton
Registration in Checkout flow was created by Meton
Hello Guys,
I just wanted to share my frustration on this website about the following:
I spend several weeks setting up a nice CSS and items in my webshop. I dint start working on the checkout because i dint have an IDEAL account yet so i left this part alone untill today.
Now i find out that i need to buy a full license in order to disable a simple function like registration. I dont want my customers to register. So i wont be using Hikashop anymore. To bad i spend so mutch time in this to find out that i configured a useless product.
Thx.
Update: Uninstalled
Thx.
Update: Uninstalled
Last edit: 13 years 5 months ago by Meton.
13 years 5 months ago #109801
Replied by nicolas on topic Registration in Checkout flow
"Useless" is quite harsh while the only thing that bothered you was that you wanted to do something which is not essential to the function of the software and that all you had to do for that would be to either modify the code yourself to do it (HikaShop Starter is open source) or purchase the Essential edition which is less than 50 euros ( which is not much compared to a few weeks of work to redo all your CSS/products settings with another ecommerce solution ) and comes with a lot of other great things in it.
Anyway, I wish you good luck with you website.
