- Thank you received: 2
Product with option not correct
- miracleecho
13 years 4 months ago #113820
by miracleecho
Product with option not correct was created by miracleecho
Scenario:
We offer a product for $6.95 (10ml) with an option for a 30ml upgrade for $16.95 (+10.00). We created a product in an unpublished category and added characteristics (this became the 30ml upgrade option for +$10.00) to the original product.
Problem:
We had an instance that the customer was only charged the option price of $10.00 instead of the $16.95. We verified that the category was unpolished and setting was correct. This could be a huge issue especially if the customer is only charged a small fraction of the total price.
Thanks for your help.
Problem:
13 years 4 months ago #113878
by Eliot
Replied by Eliot on topic Product with option not correct
Hi there,
I will need some precision. Your main product have to be in a published categories.
It's your option which have to be in an unpublished category. In this case, customer will not be able to order only the option.
Second thing is in the case customer delete the main product. You should try to enable the "Group options with product" (System>Configuration>Main>Cart) so the option is removed with the main product.
- miracleecho
13 years 4 months ago #113938
by miracleecho
Replied by miracleecho on topic Product with option not correct
We had all that right so this a.m. my client emails me and said the staff read the invoice wrong and the way it printed out confused them. So bottom line things are ok. Thanks for your continued awesome work.
