how to use badge with insert product plugin
13 years 4 months ago #114563
by ces
how to use badge with insert product plugin was created by ces
Hello
I would like to add the page on the insert product view, how can i do that there is no tags for it
- Thank you received: 1778
13 years 4 months ago #114718
by Mohamed Thelji
Replied by Mohamed Thelji on topic how to use badge with insert product plugin
That's not a bad idea, so I just added a badge option through the product insert feature that is available through the last version of Hikashop, so you should just download and install this last version.
13 years 4 months ago #115274
by ces
Replied by ces on topic how to use badge with insert product plugin
can you let me know which files you changed since i ve made some changes and i would like to avoid updating hikashop for now
13 years 4 months ago #115287
by Mohamed Thelji
I edited these files :
- hikashop2.5\plugins\editors-xtd\hikashopproduct\hikashopproduct.php
- hikashop2.5\plugins\system\hikashopproductinsert\hikashopproductinsert.php
- hikashop2.5\plugins\system\hikashopproductinsert\hikashopproductinsert_view.php
But I can send them to you if you want to.
13 years 4 months ago #115290
by ces
That would be great, also is there a way to display the custom fields on this view, i m using them to add some information like the event date of my product etc..
13 years 4 months ago #115297
by Mohamed Thelji
No, not for the moment but that can also be a good idea which will be added to the todo list
13 years 4 months ago #115311
by ces
Hello
I just put your files but it doesn t show, here is my syntax:
13 years 4 months ago #115412
by Mohamed Thelji
hum, ok the best way will probably be to directly import these plugins :
