Custom Invoice problems
12 years 1 week ago #179737 by mohairbears
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4.24
-- Browser(s) name and version -- : Firefox 33.0.3
Hi, I am trying to customise the invoice and would like to move the 'shipping address' to where the 'Billing address' currently is, I have tried to do this in order/invoice and managed to do this BUT when I change anything in this file it will then not print? is this the correct file to amend?
I have bought the PDF plugin and cannot get that to work as it produces this error
Fatal error: Call to undefined function mb_strlen() in /home/mohairbe/public_html/plugins/hikashop/attachinvoice/attachinvoice.php on line 292
12 years 1 week ago #179750 by Jerome
Replied by Jerome on topic Custom Invoice problems
The invoice PDF plugin use PHP Multibyte function in order to support UTF8 languages.
php.net/manual/en/function.mb-strlen.php
You have to be sure that your server handle the multibyte functions ; it is maybe a module to activate in your PHP server configuration.
For your printing error ; I am sorry but I don't understand the issue. Without a look to your page it is difficult to see what could be the problem.
12 years 1 week ago #179831 by mohairbears
Replied by mohairbears on topic Custom Invoice problems
Hi, PDF solved now thanks.
Where the shipping address & the invoice is placed on the invoice I need to swap their positions as I use a peel off invoice paper so the shipping address appears on the left of the invoice instead of the right.
Is there a way to alter the PDF invoice as the order number appears on there very large? plus the above would need to be changed?
thanks
12 years 1 week ago #179852 by nicolas
Replied by nicolas on topic Custom Invoice problems
Sure.
You can edit the file plugins/hikashop/attachinvoice/attachinvoice/invoice.php and change the code in it.
Swapping the addresses is easy.
Just change the line:
$addresses = array('billing_address','shipping_address');
$addresses = array('shipping_address','billing_address');
12 years 1 week ago #180107 by mohairbears
Thanks Nic...
One more then I think I have this sorted.
Is it possible to increase the white space between the 2 address boxes?
thanks
12 years 1 week ago #180115 by Xavier
Replied by Xavier on topic Custom Invoice problems
I think that you can add a "<td>" between the two addresses, so add:
<td class="my_class"></td>
After:
<td valign="top"> <fieldset> <legend><?php echo JText::_('HIKASHOP_'.strtoupper($oneAddress)); ?></legend> <?php if(!empty($order->$oneAddress->address_company)) echo $order->$oneAddress->address_company.'<br/>'; echo $order->$oneAddress->address_title.' '.$order->$oneAddress->address_firstname.' '.$order->$oneAddress->address_lastname.'<br/>'; echo $order->$oneAddress->address_street.'<br/>'; echo $order->$oneAddress->address_post_code.' '.$order->$oneAddress->address_city.' '.$order->$oneAddress->address_state.'<br/>'; echo $order->$oneAddress->address_country.'<br/>'; if(!empty($order->$oneAddress->address_telephone)) echo JText::sprintf('TELEPHONE_IN_ADDRESS',$order->$oneAddress->address_telephone).'<br/>'; if(!empty($order->$oneAddress->address_vat)) echo JText::_('VAT_NUMBER').' : '.$order->$oneAddress->address_vat.'<br/>'; ?> </fieldset> </td>
Or add css properties at the top of the file in the <style> area.
11 years 11 months ago #182964 by mohairbears
Hi Xavier, I have another problem with the PDF plugin invoice.
As you can see from the attached the wording from the 'Information' box (taken from custom fields, field type - text area) go's off the page?
Can you please advise how to prevent this.
thanks
11 years 11 months ago #182982 by Xavier
In the invoice.php file, you can potentially add a max-width property on the div displaying these instructions.
11 years 11 months ago - 11 years 11 months ago #183087 by mohairbears
Hi, Cannot find a div that refers to this?
I have sort of solved it using .hikashop_order_custom_fields_fieldset td{width: 250px;} but this leaves the text mid page and increasing/decreasing the px either moves it across the page or narrows the text box itself? below is what I have but I would like to remove the white space.
Another problem I have is when no VAT is charged a minus (-) sign is in from of the £, see below.
Last edit: 11 years 11 months ago by mohairbears.
11 years 11 months ago - 11 years 11 months ago #183233 by nicolas
Try with such CSS instead:
.hikashop_order_custom_fields_fieldset td{width: 450px;}
.hikashop_order_custom_fields_fieldset td.class{width: 120px;}
And for the taxes, instead of:
if($taxes != 0){
change that code to:
if($taxes > 0){
in the invoice.php file.
Last edit: 11 years 11 months ago by nicolas.
