Categorie picture saving problem
15 years 7 months ago #11180
by TanyaPro
Categorie picture saving problem was created by TanyaPro
I just installed the HikaShop and I created 4 categories. I tried to save a picture of the last categorie I created and the picture stays black after saving and I get this message:
Warning: imagecreatefromjpeg() [function.imagecreatefromjpeg]: gd-jpeg: JPEG library reports unrecoverable error: in /home/content/99/7225399/html/administrator/components/com_hikashop/helpers/image.php on line 306
Warning: imagecreatefromjpeg() [function.imagecreatefromjpeg]: '/home/content/99/7225399/html/media/com_hikashop/upload/gold-coins.jpg' is not a valid JPEG file in /home/content/99/7225399/html/administrator/components/com_hikashop/helpers/image.php on line 306
Warning: imagecopyresampled(): supplied argument is not a valid Image resource in /home/content/99/7225399/html/administrator/components/com_hikashop/helpers/image.php on line 261
Warning: imagedestroy(): supplied argument is not a valid Image resource in /home/content/99/7225399/html/administrator/components/com_hikashop/helpers/image.php on line 295
What can i do to solve this problem?
Peter
Peter
15 years 7 months ago #11187
Replied by nicolas on topic Re: Categorie picture saving problem
The problem is between your file and the GD library of PHP which hikashop uses to handle your images. These error messages indicates that php was not able to open your file because it is not a valid image. It can happen if your image is a GIF image but that you changed the extension of the file to jpg for example. Also, please make sure that the file is saved in RGB format and not CMYK format as that can cause issues as well.
