Export products - description ends in Product ID
13 years 10 months ago #77916 by dlarge
I have tried to export my products and view them in excel, I open up excel, import the csv using ; as the delimiter but the first 1000 lines contain the product description in the product id column, then after all the descriptions are exhausted, the rest of the csv file looks fine and everything is where it should be. Maybe im importing into excel incorrectly?
Any help greatly appreciated.
Dave
13 years 10 months ago #77925 by Xavier
Yes I think that the problem come from excel, try to open the csv file with another program.
The following user(s) said Thank You: dlarge
13 years 10 months ago #78242 by dlarge
Thanks - it appeared to work ok in google docs spreadsheet.
Can anyone recommend a good csv file viewer so I can sort columns and edit properly?
Dave
13 years 10 months ago #78261 by Jerome
You can use OpenOffice.
It can open and create CSV files.
13 years 10 months ago #78613 by dlarge
Thanks - Completely forgot about open office!
Time to create page: 0.193 seconds
