- Thank you received: 14235
Required checkbox during registration
15 years 1 month ago #23160
Replied by nicolas on topic Re: Required checkbox during registration
Indeed. Please replace the file media/com_hikashop/js/hikashop.js with the file in the archive enclosed. That should solve the problem.
15 years 1 month ago #23799
by lrazov
Replied by lrazov on topic Re: Required checkbox during registration
I have the same issue - a user can register without checking the t&c check box.
Do you have any solution to this? Should I try the previously provided solution?
15 years 1 month ago #23800
Yes, you should try the above mentioned solution.
15 years 1 month ago #23844
by lrazov
Hi, the provided solution didn't fix the issue. I can still register without selecting the t&c check box.
15 years 1 month ago #23859
The js files are usually cached by your browser. Please make sure that you clean your cache before trying. If you still have the problem after tht, please give a link to your website.
15 years 1 month ago #23920
by lrazov
I've cleared the cache, but the problem persists. I've sent you access details via PM. Look forward to hear from you soon.
15 years 1 month ago #23969
by lrazov
I did some further testing and here is what happens:
First of all I need to say that I need the t&c to be part of registration process rather than checkout.
Right now the t&c check box appers twice under the rego form and on the checkout page. When a user registers the t&c is not validated. But it is validated as part of checkout process, here I mean if I try to proceed to payment step without selecting the t&c box, I get the expected error message.
I hope this helps to understand what's going on.
Thank you.
Thank you.
15 years 1 month ago #24053
It's indeed how the system is now. The t&c system is to be used at the end of the checkout for the validation of the order.
If you want to have a similar checkout for the registration of the user, you should use a custom field of the table "user" and that will work.
Time to create page: 0.180 seconds
