Add short descriptions under products in listings
16 years 4 days ago - 16 years 4 days ago #1331 by Redeemer
Hello again,
Our website is nearly complete. However, I would like to know if or how I can add short descriptions under my products when I am viewing a product listing. It would also be great if I could add a Read more... button at the end of the short descriptions.
The reason we would like to do this is because we are worried that our customers may not immediately realize that clicking on a product will simply show it in more detail, rather than actually purchasing it.
Thanks for your time,
-Redeemer
EDIT: A small 'Details' button would do the trick too, if that's possible.
Last edit: 16 years 4 days ago by Redeemer.
16 years 4 days ago #1334 by nicolas
You can go in Display->Views and search for "listing_img". There you will have several files that you can customize. It depends on the option "item layout" of your menu/module. Suppose that you use the default one, "image and title", you will have to edit the listing_img_title.php file.
There, you will be able to modify the HTML the way you want. If you just want to display a button below the name of the product you can add the code
echo '<br /><input type="submit" class="button" name="Details" value="Details" onClick="window.location=\''.$link.'\'"/>';
just after the code
echo $this->row->product_name;
near line 20.
16 years 4 days ago #1337 by Redeemer
Well, I did what you suggested and indeed the results are good... But I would also like it if the Details button appeared in product modules, too. For some reason this isn't happening, although I added the code to the products->listing_img_title.php script.
16 years 4 days ago #1339 by nicolas
Like I said, maybe you use another item layout than listing_img_title ? In which case, you will have to edit the corresponding view file. Maybe listing_title ? If you do a screenshot of the options of your module, I would be able to tell you which one to modify.
16 years 4 days ago - 16 years 4 days ago #1340 by Redeemer
I've attached an image file that shows the Hikashop module properties for a "Latest Products" module I have:
16 years 4 days ago #1344 by nicolas
Your options are good. There is no reason for the button not to be displayed.
Could you give a link of the problem ?
16 years 3 days ago #1359 by Redeemer
Sorry, I'm building my website offline. It's being hosted in a VM that's hidden in our intranet.
16 years 3 days ago #1362 by nicolas
Then try to make the modification into all the listing_img files the listing_title file. That's got to be one of them.
16 years 3 days ago #1363 by Redeemer
I've tried adding the button to several of the views, but none of these additions seemed to have solved the problem. :huh:
This is very strange...
16 years 3 days ago #1364 by nicolas
Maybe you could make a screenshot of the whole page where you have the problem ?
16 years 3 days ago #1368 by Redeemer
The problem occurs on any module regardless of view type except for my 'Product Listing' page.
Here's a screenshot of the listing page with the desired results...
16 years 3 days ago - 16 years 3 days ago #1370 by Redeemer
And here's a screenshot of the frontpage, where you can clearly see that the 'Latest Products' module is missing 'Details' buttons.
The same problem shown above also occurs when I look at a list of products under a specific product category.
Last edit: 16 years 3 days ago by Redeemer.
16 years 3 days ago #1386 by nicolas
I'm out of ideas. The lsiting of products on both screenshots uses the same file listing_img_title.php
So, if you changed the code as I said, you should get the same result.
16 years 3 days ago - 16 years 3 days ago #1387 by Redeemer
Ok, here's my entire listing_img_title.php file...
<?php /** * @package HikaShop for Joomla! 1.5 * @version 1.3.2 * @author hikashop.com * @copyright (C) 2010 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?> <?php $link = hikashop::completeLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway);?> <div style="height:<?php echo $this->image->main_thumbnail_y;?>px;text-align:center;clear:both;" class="hikashop_product_image"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->product_name)); if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </div> <?php if($this->params->get('show_price')){ ?><br/><?php $this->setLayout('listing_price'); echo $this->loadTemplate(); } ?><br/> <span class="hikashop_product_name"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_name; echo '<br /><input type="submit" class="button" name="Details" value="Details" onClick="window.location=\''.$link.'\'"/>'; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </span> <?php if($this->params->get('add_to_cart')){ ?><br/> <form action="<?php echo hikashop::completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->row->product_id.'_'.$this->params->get('main_div_name'); ?>"><?php $this->setLayout('quantity'); echo $this->loadTemplate(); ?> <input type="hidden" name="product_id" value="<?php echo $this->row->product_id; ?>" /> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> </form><?php }?><?php /** * @package HikaShop for Joomla! 1.5 * @version 1.3.2 * @author hikashop.com * @copyright (C) 2010 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?> <?php $link = hikashop::completeLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway);?> <div style="height:<?php echo $this->image->main_thumbnail_y;?>px;text-align:center;clear:both;" class="hikashop_product_image"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->product_name)); if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </div> <?php if($this->params->get('show_price')){ ?><br/><?php $this->setLayout('listing_price'); echo $this->loadTemplate(); } ?><br/> <span class="hikashop_product_name"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_name; echo '<br /><input type="submit" class="button" name="Details" value="Details" onClick="window.location=\''.$link.'\'"/>'; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </span> <?php if($this->params->get('add_to_cart')){ ?><br/> <form action="<?php echo hikashop::completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->row->product_id.'_'.$this->params->get('main_div_name'); ?>"><?php $this->setLayout('quantity'); echo $this->loadTemplate(); ?> <input type="hidden" name="product_id" value="<?php echo $this->row->product_id; ?>" /> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> </form><?php }?>
I put the code snippet you made on line 34.
Perhaps this will be helpful to you.
16 years 3 days ago #1388 by nicolas
That code is fine.
I was expecting that, otherwise, it wouldn't display the details button anywhere.
16 years 3 days ago - 16 years 3 days ago #1396 by Redeemer
Well, I need this to be done, and I don't have much skill when it comes to PHP, so...
Does anyone have any ideas?
EDIT: I noticed earlier today that I can put <Read More> tags in product descriptions, but they don't seem to do anything.
Perhaps it would be a good idea to make these tags functional, so that you can set a product to appear with part of it's description in a list... And when you press the 'Read more' button, it takes you to the product page.
16 years 3 days ago #1397 by nicolas
I was thinking again about that problem...
Maybe it could come from a caching issue ? If you cache the modules content on your website that's something which could happen since the HTML was already generated, you would not see your modification on the modules. You could easily check that by changing the color of the module background in the options of the module. If it doesn't change when displaying the module, then it's likely that it's a caching problem.
16 years 3 days ago #1410 by Redeemer
Sorry, I've tried clearing my cache to solve the problem... The problem doesn't seem to lie there, either.
16 years 2 days ago #1483 by Redeemer
Ok, I solved the issue for myself. Here was the problem:
For whatever reason, there are TWO listing_img_title.php files that hikashop uses. One is kept under the template you are using, in my case "rhuk_milkyway":
/templates/rhuk_milkyway/html/com_hikashop/product/listing_img_title.php
This one can be edited right through the Display->Views menu in the back-end of your Joomla! installation.
The second file is kept in:
/components/com_hikashop/views/product/tmpl/listing_img_title.php
For whatever reason, the Product Listing component uses the first one, but all other modules use the second.
It is my guess that they use two files because one is needed for template-specific layouts, and one is needed for generic modules.
At any rate, if you want a 'Details' button, or any other modification, to appear no matter if the products are appearing as the content or as a module, you must make the changes to BOTH files.
So, thanks for your help anyway, Nicolas; it was your code that helped me accomplish this in the first place. ;)
-Redeemer
16 years 2 days ago #1485 by nicolas
Hum. Interesting. Normally, the file in the template should always be used by joomla if there and the other one ignored. That's the principle of the override of views in joomla. Be it in a module or as main component. It's strange that it's not the case on your website.
Time to create page: 0.106 seconds
