Product code auto generation
15 years 1 month ago #23983
by lrazov
Product code auto generation was created by lrazov
Is it possible to configure the system so it auto generates product codes once a new product created?
Thank you.
Thank you.
15 years 1 month ago #23984
by lrazov
Replied by lrazov on topic Re: Product code auto generation
One more enquiry...
I am using PayPal plugin as a payment method. Could tell me where in the code an order status gets updated to confirmed? I need to do something at that point in time.
Thanks a lot.
P.S. Sorry I added this message to this post as I didn't want to open a new thread just for one question.
Thanks a lot.
15 years 1 month ago #23987
Replied by nicolas on topic Re: Product code auto generation
The product codes are already generated automatically when the product is created.
If you want to do something when the order status changes, the best is to create a hikashop plugin and implement the onBeforeOrderUpdate or onAfterOrderUpdate events as explained in the developer documentation:
www.hikashop.com/en/support/documentatio...r-documentation.html
You can also edit the save function of the file administrator/components/com_hikashop/classes/order.php directly but your modification will be erased when you update HikaShop in the future.
15 years 1 month ago #24014
by lrazov
Thank you for the suggestion.
Regarding the code auto generation - I can see that the code is being generated from product title. It's not very convenient to have rather long codes. Is there a way to use some sort of algorithm for this, like you do for order # where we can use various things, like date, strings, etc?
15 years 1 month ago #24016
by lrazov
I found this plugin plgHikashopAcymailing which implements the onAfterOrderUpdate function. Could you explain what it does on order status update? May be it's exactly what I need. I need to subscribe a user to a mailing list on order status update. Am I in the right file for this?
15 years 1 month ago #24027
If you want to have other types of product codes, you should create a hikashop plugin and implement the onBeforeProductCreate event:
There, you can just set yourself the product code in the product_code attribute of the object given and that will use your product_code.
The plgHikashopAcymailing plugin triggers the filter system of acymailing when the status of an order is changed. With the filters of AcyMailing (with the enterprise edition) you can save a filter to subscribe someone to a specific list and set that filter to run when an order is confirmed.
Then, thanks to that plugin, the filter will be triggered automatically when orders are confirmed and your customers will be subscribed to the list you want at that point. So it seems to do exactly what you want.
15 years 1 month ago #24068
by lrazov
Thank you for the advise. I have never created a plugin before. I suppose I can figure out how to write one by looking at other plugins, but how do I make it to be used by the product save function? Any advise would be highly appreciated. Also, could I reuse in the plugin the same function you use for order number generation?
15 years 1 month ago #24082
The product save function triggers an event before and after saving a product. If your plugin implement these events, they will be called automatically if you plugin is published in Joomla.
There is nothing special to do as long as you do your plugin like the other plugins already available.
You can't reuse the function we use for the order number generation. The code will have to be different as the order number generation code needs the order info, and wouldn't use the product info.
15 years 1 month ago #24087
by lrazov
Thank you. I'll give it a go...
Time to create page: 0.220 seconds
