Import manufacturer names and assign to products ?
15 years 1 month ago #24121 by Karloz
Is there any way how to import manufacturer names and assign them to the products please ?
I tried to do that via product import & manufacturer_id column, but without success
thank you very much,
Karloz
15 years 1 month ago #24137 by nicolas
Yes, you can have your manufacturers in the product_manufacturer_id column of your CSV and they will be imported.
15 years 1 month ago #24176 by Karloz
hi yep i tried to import:
product_id, product_code, product_manufacturer_id
or only
product_id, product_manufacturer_id
and no product has been assign to a manufacturer (product_manufacturer_id was text)
also no manufacturer appears in manufacturers back-end
then i exported all products and the manufacturers are shown in categories column at the beginning, with null parent_category column
i would like to import products with a manufacturer name to be able to browse products by manufacturers...is it possible ?
thank you,
karloz
15 years 1 month ago #24178 by nicolas
Please change the code:
$id = $this->_createCategory($product->product_manufacturer_id,'manufacturer');
$id = $this->_createCategory($product->product_manufacturer_id,0,'manufacturer');
in the file administrator/components/com_hikashop/helpers/import.php
and import the CSV:
product_code,product_manufacturer_id
my_prod,my manufacturer
15 years 1 month ago #24182 by Karloz
Yep it works very well thank you very much, but there is one more issue .. i imported:
manufacter name correctly assigned to the product,
but product_quantity changed to unlimited on all products, i think it should keep the previous quantity
also is it possible to set UTF-8 coding as default for import please ?
15 years 1 month ago #24184 by nicolas
for the quantity, removing the code
else{
$product->product_quantity=-1;
from that same file will solve that problem.
The unknown format should use UTF8 or another format based on what the system detects so it should work in most cases.
Time to create page: 0.296 seconds
