Cart module shows random products after checkout
15 years 1 month ago #24146 by shifty_
Hi There, I have just installed Hika Shop for the first time and I have to say, I am very, very impressed. So far everything has either been easy to figure out or it has 'just worked'.
I am just having one issue that I can't seem to solve. After you go through the checkout process and put in the credit card details (currently running in the eWay test environment), once you get the Thank You message the Mini Shopping Cart Module displays a product and quantity that is unrelated to the order. I assume it is pulling something from a previous session or something, but I get it happeneing in Chrome and FireFox (haven't testing IE or Safari as yet).
Anyone know what that is and how to rectify it? I would like to either empty that mini cart on that Thank You page or have the product and quantity from the latest order that just went through.
I have tried searching for a solution to this but without luck, so am posting now for some help.
Cheers
shifty
15 years 1 month ago #24154 by nicolas
The carts of the users are stored in the database. When you clean one cart, the cart after it is loaded. If you clean all the carts of your user, you won't get that behavior anymore.
If you don't want to system to store previous carts, you can change the cart retaining period options of the configuration of HikaShop.
15 years 1 month ago #24212 by shifty_
Thank you very much - the support is great!!
Time to create page: 0.170 seconds
