- Thank you received: 2
Few Questions: Backend order, Taxes and checkouts
After installing the new version i was very impressed by the many upgrades.
I have some questions i cannot find answers:
1. I would like to make an order from the back-end, if i do so, i need to charge the customer too. Example: i make an order filling all the products and info and when i choose the payment method nothing happens, so i cannot charge him via back-end order. I need the option Payment method to be able to run the onAfterOrderConfirm(), how can i manage that?
2. I need to have checkout by registration info. Means when i checkout without checkbox that says affiliate i want him to pay more for products and display less fields in the registration.
Example: An affiliate is trying to register, he marks the box and fields are added (Done that), now i want him to recieve a discount on some products and district him to only part of payment methods. When a normal customer trying to register, part of the fields are displayed and checkout goes without any affiliate discounts.
3. Can i have a custom fields visible or invisble in the registration depands on the products in the cart? lets say if this products is the only one then i want him to view less fields.
4. I have read the USA tax system and i did not understand one thing. Can i choose a different product price per state?
I know thats many questions.. but
Thank you very much for the attention!
The order creation system just allows you to create the order. Then, you can send him an email notification (by changing the status for example), and ask him to pay his order from the front end (there is an option in the Checkout tab of the config so that the user can pay orders from his orders listing when he is logged in).
2. There is no option for that. That will require to add custom code in one of the files of the checkout view to add the coupon based on the affiliate checkbox value.
3. Not in the registration. You can do that with custom item fields on the product page for each product.
4.No. You will have to setup the taxes in the taxation menu
if i want to display like paypal payment plugin that displays redirection to paypal and purchase through paypal, could that be implant in the back-end order?
Another question i need to find is the export button for orders:
If you can help me with that, it will be great..
How can i modify or view the .csv file? ( i need to export orders to excel)
The export button for orders in the sales listing page at the top right.
That will give you a CSV that you can open with Excel.
im asking how can i see the params he is taking and manage them, and how can i view it normaly in the excel?
Could you do a screenshot ?
Could you check that the option "menu position" of the configuration is set to "under the title" and try again after changing it if that's not the case ?
The CSV is generated in the file export of the view product of the back end. You can edit it via the menu Display->Views.
I have seen the export view and it looks good, i will customize it later.
Thank you.
You should change that in the "Files" tab of the configuration.
One problem is how can i set a fields to be UTF-8, because i have some hebrew text that is displayed as gibberish?
And another question, i managed to delete from echoing the fields i dont need, but the excel is showing me empty columns as if it counted them before..
How can i remove the spaces created when i filtered the echo by my require fields?
Your second question is too vague so I can't help you
if($key != "order_product_name" && $key != "user_id" && ...){
echo '"'.str_replace('"','""',$key).'"';
Means i do not echo user_id ,order_product_name and so on titles.
and for the values i did the same:
echo '"'.str_replace('"','""',$val).'"';
Means i do not echo the values of all fields named user_id ,order_product_name and so on.
Somehow the excel still consider the columns and fill them with blank. (as seen in the screenshot)
Normally, that should have been in:
foreach($columns as $column){
if(!empty($column)){
$output.= '"'.str_replace('"','\\'.'"',$column).'"';
$output.= $separator;
and:
foreach($products_columns as $column){
echo '"'.str_replace('"','""',$product->$column).'"'.$separator;
If excel still leave the column, it means that you're still displaying the $separator for that column.
