Order of characteristic NAMES, not values
14 years 11 months ago #28643 by Jims
I have two characteristics, Size and Colour. I always want Size to be the first in order, so that the sizes are the rows of the characteristic table.
Several times I have gone through every products and set the order number for size to be 1 and colour 2.
But after updating via a csv, the 1 and 2 settings are lost and I have to do it all over again.
How can I set Size to Characteristic 1 and Colour 2, and have this setting stay permanently?
Jim
14 years 11 months ago #28655 by nicolas
The ordering column of characteristics is not kept when you update via CSV a product with characteristics.
I'm not sure, but the order is either taken by the order of the characteristics in your CSV (in which case you could just swap both columns in your CSVs in excel and then reimport your products) or by the order of creation of the characteristics (in which case you could delete one an recreate it in order to swap them, and then reimport your products).
Time to create page: 0.134 seconds
