what view to edit.....
14 years 11 months ago #28995 by plumbingdeals
for the area circled in red on this page
14 years 11 months ago #29008 by nicolas
Replied by nicolas on topic Re: what view to edit.....
If you want just to change the text/remove it, you can override the translation as explained there:
Otherwise, that can be changed in the file login of the view checkout and the file registration of the view user that you can edit via the menu Display->Views.
14 years 10 months ago #29067 by plumbingdeals
got it! did the trick...thanks
btw, we have purchased the essential version as we prepare to launch our site.
test site can be viewed here... testsite.decorativeplumbingonline .
couple of additional questions, please....
on the login form of the cart page, i would like to move the statement "Fields marked with an asterisk (*) are required. " to the top, but I can't find where to change this.
also, when doing a search for say "Hansgrohe" on the front-end, one of the results is for the manufacturer Hansgrohe which is correct, however when you click that result, the page is blank. On uploading our products we did assign them to the manufacturer id # (14). Should the products appear?
thanks for the great support!
14 years 10 months ago #29082 by nicolas
You can change that in the file registration of the view user that you can edit via the menu Display->Views. It's the code:
<tr class="hikashop_registration_required_info_line">
<td colspan="2" height="40">
<?php echo JText::_( 'HIKA_REGISTER_REQUIRED' ); ?>
</td>
</tr>
If the page is blank, it's because of the itemid field of the hikashop category search plugin. You need to set in that option the id of a hikashop category listing menu.
14 years 10 months ago #29090 by plumbingdeals
once again, great support!
first problem solved...
second problem, i get what you are saying, but i need to tweak it a bit.
thank you!
Time to create page: 0.183 seconds
