Associated products are also showing in cart
14 years 10 months ago #29466 by Biird
I have a problem.
I have enabled Associated articles/products.
They are working fine under an individual product. But it also shows a list of products under the Cart/checkout!
(and also under my catagories-page)
How can i turn off the visabilitie underneath the cart and this other place?
See my screenshots for what i mean.
Hope you can help!!
14 years 10 months ago #29467 by Biird
and under the cart:
14 years 10 months ago #29477 by nicolas
The related products module should be unpbulished in joomla and enabled in the option "Modules under the product page" of the Display tab of the configuration, as explained on that documentation page:
www.hikashop.com/en/support/documentatio...ct-form.html#related
So please modify that and it should work properly.
14 years 10 months ago #29722 by Biird
Thanks, that was working for the cart, but it is stil visable under my catagorie's 'menu'.
(second screenshot in this topic)
If i unable the products in the accociated module of this menu, all the products dissapear.
Is there a way to make this unvisable?
14 years 10 months ago #29738 by nicolas
Then, the problem comes from the options of your module.
You should set the "sub element filter" option of your module to "direct sub elements" instead of "all sub elements".
14 years 10 months ago #29748 by Biird
It already stands on direct sub elements..
14 years 10 months ago #29788 by nicolas
I'm sorry but I'm guessing with the few elements you gave.
Please give the URL of that page and I should be able to give you a better answer.
14 years 10 months ago #29890 by Biird
14 years 10 months ago #29911 by nicolas
Go in Display->Content modules and edit the module with the id 43. There, change the "sub element filter" option to "direct sub elements" instead of "all sub elements".
14 years 10 months ago #29928 by Biird
It already is on 'direct sub elements'..
14 years 10 months ago #29957 by nicolas
Could you do a screenshot of that screen ?
14 years 10 months ago #30124 by Biird
The screenshop of module wirh id 43:
14 years 10 months ago #30163 by nicolas
Are you sure that the products displayed on the main categories page are not linked to that category ? Because I don't why they would show there if that wasn't the case with the options you have for that module.
14 years 10 months ago #30418 by Biird
i found it! the problem was that there were some uncategorised products.. so they showt 'lose' in catagories.
Thanks for al the thinking and help anyway!
Time to create page: 0.269 seconds
