How to cut long product names in shopping cart?
14 years 10 months ago #29765 by websquirrel
is there a possibility to shorten or cut long product names for display in shopping cart? It would be very handy, if there could be set a shortname for products displayed in the cart or if I could set a maximum number of letters for names displayed in cart ... :blush:
14 years 10 months ago #29790 by nicolas
On the hikashop cart module ?
Yes, you need to edit the file "cart" of the view "product" via the menu Display->Views and change the code:
$row->product_name
by:
substr($row->product_name,0,50)
Time to create page: 0.160 seconds
