Displaying product weight on product description
14 years 10 months ago #29892 by wonderwilson
Hi Guys,
We would like to add the product weight to the product description page - how do I go about adding this?
Darren
14 years 10 months ago #29908 by wonderwilson
I've tried adding the following:
Minimum Weight: <?php echo round($this->row->product_weight,1)?><?php echo $this->row->product_weight_unit;?><br>
To the product/show display, but it returns a zero - any ideas?
Darren
14 years 10 months ago #29925 by nicolas
The weight is already displayed on the product page but in a hidden div.
You can display it with some CSS:
.hikashop_product_weight_main{ display: inline !important; }
14 years 10 months ago #31534 by wonderwilson
This works, thanks Nicolas.
However, I'm getting a 5g rather than a 500g - any ideas?
Darren
14 years 10 months ago #31563 by nicolas
Do you have the latest version of HikaShop ? If not, you should update.
If yes, go in the menu Display->Views and edit the file "show" of the view "product". There search for the text product_weight and make sure that you have the line of code:
<?php echo JText::_('PRODUCT_WEIGHT').': '.rtrim(rtrim($this->element->product_weight,'0'),',.').' '.JText::_($this->element->product_weight_unit); ?><br />
14 years 9 months ago #31764 by wonderwilson
This works perfectly. Thanks.
Darren
Time to create page: 0.207 seconds
